MT2000 Problem (will not Rx until Tx)
NateDogg1110
ohio
What would cause this problem? I have a couple of Motorola MT2000 VHF radios with this problem. On any given channel, the radio will not receive until you transmit on that channel. Once you have keyed up, then transmissions begin coming through fine until you turn the radio off or change channels.
Troubleshooting steps:
I have read a radio that was programmed the same way, then read one of the trouble radios. I then compared both line by line, feature by feature. Everything seems to be the same.
Can anyone advise?
evfd1625
Indiana
re
I had an HT1000 that did the same thing. Wouldn't even light up on the top to show the channel busy. Would key up and it would receive, other than that never figured it out. As long as I left battery on, It wouldn't have the same problem upon power up, but if battery was removed it would need to be keyed again.
NateDogg1110
ohio
I will double check the Quick Call Paging and report back. I'm pretty sure that it is not enabled.
NateDogg1110
ohio
Ok That was the issue. It was the Quick Call being set to AND. I moved it to OR and bam, the radio works how it is supposed to. Nice. Thanks a million trlrdrdave!!!!!!!!!
