MT2000 Programming Question
AZ_chris
Glendale, AZ
Hi guys,
I'm looking at a MT2000 on eBay.
If it's Flashcode is for Smartnet Systems Operation, can it be used strictly for conventional systems, or is it a trunking-only radio?
Thanks!
IAmSixNine
Dallas, TX
I could be wrong but i thought the MT2000 units were conventional only.
The MTS2000 were conventional and trunking.
Going by memory here as its been a long while since i played with an MT2000.
Also you need a true dos computer to program them, a dos box wont work.
n8dhw
Middletown, Ohio
Hi guys,
Thanks!
Not aware of MT2000 being Flashable so I don't think a Flashcode would apply but I could be wrong.
So, as others have said, the MT2000 is not a trunking radio, you probably meant the MTS2000, which will do SmartNet and SmartZone trunking.
Yes, an MTS2000 with a flash code that includes the StartSite, SmartNet or SmartZone trunking can be programmed to do conventional channels just fine.
