Mt2000 solid tone on key up after programming
Frank00213
I programmed my uhf mt2000 to the proper freqs and pl codes. When i try to transmit i get a solid tone. Im not sure why. This is used for work.
Frank00213
Help with MT2000 UHF
Hello all so im having an issue with my MT2000 uhf radio. I programmed all work channels into the radio. My issue is when i try to transmit on set freq it gives me a constant tone when the ptt os pressed. I dont have it set to receive only and it is not set for tx inhibit. The freqs are correct as well as the pl code. Their is no signalling set like ge or star. Any help will be appericated. I am using mtsx rss for the radio version 06.02 i believe.
