MTR3000 CPS Version
robertsdoug
Does this repeater require a separate CPS to program it, or does the same CPS that programs radios work? If so, what version of CPS work? Thanks
KG4INW
Midlothian, VA
Regular MOTOTRBO CPS, equal to or greater than whichever version it was last programmed with along with a standard USB A to B cable is all that's needed.
robertsdoug
Perfect. So I’m assuming that based upon this, the most recent Motorola CPS will work?
KG4INW
Midlothian, VA
I suppose you might have some issues if trying to program a used unit that hasn't been touched in a really long time, but yes, they use TRBO CPS, including the most recent. If that won't work, I believe you'd need to increment the firmware and get it up to being useable with original TRBO CPS (16.0 build 828 was the last version) but that's worst-case scenario.
btritch
When you say Motorola CPS. I have the CPS software for the XPR 3500 and 7550. Will this same CPS software work for the MTR 3000 repeater?
And is there any specific programming cable ?
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Read response #2.
