MTS-2000 Help!!
KG6GTH
Los Angeles County, California
Have an MTS-2000 with top display.
I was told that this has more that 48 channels (16 channels w/ 3 zones)
How do I acess the other zones???
I was also told I need to get a different channel knob that needs to turn 360degrees to acess other channels....
Can anyone help??
Thanks.. Please e-mail me @ kg6gth@aol.com
Thanks -Sean
PJH
Use the ABC switch if it has been programmed for the zone selection. That is how you get the other zones.
Flow chart:
Enable zones
Program toggle switch for zone selection
Enter personalites
Select which personalities you want in each zone
Setup a scan list per zone
Program the radio
That's basically what you need to do
e231
SC
mts2000 model I
That's what you have with a top display unit, a model I with 3 zones/ 48 modes. Unless someone recased a mod II or III. Check the model #, begin with the radio off, power it up, wait for the self test to clear, press the SB3 (the one with two dots above the PTT) 5 times witin the first ten seconds after power up, this will scroll through the mod#, s/n, and other info depending on the software. Look at the sixth position in the mod #, if it is a mod I, it is D, mod II= F, mod III= H. Sorry. I have a mod II or III 800 I would like to part with if that would help. PM me for dt's. -Brian
