MTS2000 flashcode version
k4njk
Coral Springs, FL
How do I determine the flashcode version for a Motorola MTS2000. I have placed the radio in service mode and LCD display indicates the firmware version (05.44), model number (H01KDD9PW1BN), then the serial number (432AVSnnnn) and then displays RF TST.
Josh
Auburn Hills, Michigan
It should appear in the test screens. If it doesn't, then read it with a computer running CPS/RSS. If the radio has no flashcode, then it's possible that you have a rehoused MT2000.
RBMTS
Some of the earlier versions of the MTS2000 radios did not show flashcodes. Not being able to see a flashcode does not necessarily mean you have a MT2000.
k4njk
Coral Springs, FL
I believe I found the flashcode on the lower left hand corner of the factory tag. The number that appears in fine print reads 00000010000009.
WayneH
Forums Veteran
Your master site
fineshot1 said:
I am not certain but I think you have one too many digits in this flashcode.
It's correct. 13 total digits. 6 dash 6 dash the single checksum digit.
k4njk
Coral Springs, FL
The fine print reads 000001-000000-9. I had an extra zero in the beginning of the number. Guess it's time for new glasses :)
fineshot1
NJ USA (Republic of NJ)
OK - If you go to that flashcode decoder address I provided above you will get this:
Options Installed on this Flashcode:
000001-000000-9
H35/G48 Conventional Operation
Just the one option in the flashcode - Hope that helps
