mtx838 programming
johndoesefi
israel
hello.im trying to program my mtx838.
im using win xp and im trying running the mtsx program threw dosbox 0.74.
i have the rib box and the programming cables.i also use an rs 232 to usb adaptor.
i understand that in the dosbox software there is a spesific amount of cycles that you need to configure.
is any body knoes the exact mount of cycels to use?
will much aprritiate the help/
thanks
cmjonesinc
You'll need to ditch that rs232 to USB adapter as well. Something that old is going to require straight rs232 and actual dos. Dos from USB is the easiest if your computer can boot from usb
cmdrwill
So Cali
Correct,the software only runs in REAL DOS and does not work with USB,
johndoesefi
israel
thank for the tip guys.will it work on vm box machine?
i was able to install dos 6.22 on vm virtualbox(after i was busted my head untill i finnaly got it threw)but havent yet succeded on setup the "guest additions".which mean im un able to add files and aoftware to try run them on the vm.(im still busting my head on it)after watchig lots of videos on the net,and i have tryed everything.does any one have an idea how to do it?
gtaman
TACSAT
GALAXY 19 91.0° W
Just make a dos USB stick and boot it from startup. I set my tough book to boot USB first. So all I do is turn it off plug in the USB then boom DOS boots. When I'm done I just turn off and unplug it. Then I am back at XP
johndoesefi
israel
Thanks.i will give it a try.hope it finnaly solved my problem.it is much more easy than work on vm virtualbox
johndoesefi
israel
Dear guys.i have finnaly got it threw.thanks for every one for the
Assistance and for your tips.you have no idea how much you
have helped me.you are doing excelent job.
Sincerly and regards
johndoesefi
israel
mtx 838 signalling program
hi guys.is any body knows how to add a mdc1200 signalling?is this possible in this model?
Sincerly eitan
cmjonesinc
I believe you can have mdc but you need firmware 1.3 and up.
johndoesefi
israel
i use the latest firmwar.if im not mistaken its the 06.07.00.
when i try to program the signalling in the frequency area,and i try to change any signallin type,it does not give me any options.it give me options only in the service mode,but it is not what im looking for
johndoesefi
israel
i also have an ht1000 radio,and it gives me all the options.is it posible that i dont have that function in my radio?
cmdrwill
So Cali
'Signaling' IS set up in a separate screen. Then select MDC and the code. Then in the 'frequency' screen the MDC should be available.
johndoesefi
israel
basicly you are right.that how i program my HT1000 that way.
in my rss,it gives me 2 places to find it.
1.in the sevice alignment screen.
2.in the conventional system screen.(the F6 buttom)
but i have'nt able to change\edit nither one of them
