Multi Band Hand helds?
crazycanuk
Ontario
Hello, Im a complete newbie here. I am in the market for a Icom IC-A24 as I am a pilot. I then started to wonder if there were hand helds that would also do CB and HAM Freq RX\TX. Are there radio's like this or is this a dream radio:)
Thanks in advance
fineshot1
NJ USA (Republic of NJ)
Thanks in advance
When you say ham radio - you do not specify a band(there are many ham bands),
ie: 10 meters, 6 meters, 2 meters, 220mhz band, 70cm band, 33cm band, 23cm band
CB is 26/27Mhz band just below the commercial vhf low band(30-50Mhz).
What you seem to be dreaming about is not yet practical by today's technology
for an all in one HT and would also be tough for a radio salesman to sell as there
is no market for it.
EDIT: Forgot to mention - there are multi-band ham ht's but they are just ham
and do not mix in commercial bands.
CLynch7
North GA
Thanks in advance
The Vertex Standard Pilot series are great air handhelds (I've got a VXA-210 I carry as a backup in my flightbag). Yaesu makes great radios, multi-banders too. I've got my eye on
a VX-5R, 50/144/430MHz Bands. As for handheld CB radios, most a poor performers. They may receive well, but TX has very little range.
crazycanuk
Ontario
So for the plane I'll have to get just a regular aircraft HT in the 118 ~ 136.975 mhz.
for a second radio would a Yaesu VX-3R be considered a good entry lever HT?
VX-6R and VX-7R would be preferred though?
One other Question, any transceiver that does 420-470MHz can be programed to work FRS band?
tekshogun
NC
The only thing I can think of is a 10 meter hand held that is not restricted to the ham bands. I have never seen anything like that. I use a VX-5R which only transmits on 6m, 2m, and 70cm ham bands. The Yaesu FT-817 is an all mode all ham band but I honestly do not know if the CB frequencies are blocked (being a radio built for amateur radio operators) from TX. The FT-817 is not a handheld but it is an ultra-portable mobile rig that can use battery power and has a an antenna connecter for the VHF and UHF communications and one for HF (50 MHz or 6 meters and down).
tekshogun
NC
What you need is a multi-band ht that is not made specifically for ham radio if you need it for other bands such as air or marine.
I use the VX-5R which can be modified, illegally, to transmit out of band (the so called MARS/CAP mod). My radio was built for and currently transmits on the amateur 6m, 2m, and 70cm band (50MHz, 144MHz, 430MHz respectively).
You may be better off getting a low band HT that can operate all the way down to that 10 meter/CB frequency range and an HT that can do the other bands that you want.
