multi offset & base
osiris
Doylestown, Pa
Hi Guys,
MY question is, can you set mulyiple base & offset freq in a PRO-96.
Burlington Countylists 3 offset and base freq & I don't see that option in the owner's manual. Or should I post this in the 96 forum.
Thanks for any input.
Bob Findlay
RocketNJ
Pequannock, NJ
Yes, easiest way is to buy the programming cable and Don Starr's Win96 software.
George
osiris
Doylestown, Pa
multi base and offset
Hi George,
Thanks for the quick reply. I'll have to get that when I get around to it (and the money).
Thanks again
Bob
burlcoradio
correct multi table for Burlington County
Since were on this topic..
I noticed that the multi tables listed in the radioreference.com database and those listed at bcfirechiefs.org are not exactly the same.
http://www.bcfirechiefs.org/radio/north_region.htm
http://www.radioreference.com/modules.php?name=TRSDB&sid=1320
The difference I am noting is the 2nd base frequency. Should it be 502.425 or 502.450? Does it even matter since the frequencies are so close? I will be using WIN96 to load the table into a PRO-96 when it arrives.
One more question..
What should the CH Lo and CH Hi values be set to?
Paul
jcardani
Orlando, FL
Hi Paul,
Here's the correct plan for the county (taken from my Philly Guide E-Book):
Chan Low Chan High Base Freq Offset Step Size
380 529 500.32500 380 12.5
530 558 502.42500 530 12.5
559 759 506.47500 559 12.5
Joe
http://www.PhillyScanner.com
burlcoradio
Joe,
Thank you for the correct information! I managed to come up with the same CH Lo and CH Hi numbers after mulling over the default extended tables within Win96. Your confirmation has been a great help.
Paul
