Multiple 2 tone decoding
hfd26
I knew that was the issue were talking about I just didn't know if the same issue was happening on a 7/800 trunk system. The 7/800 truck system I listen to for my mutual aid company doesn't set there tone over the trunk system
TFrank615
Springfield, Ohio
Sorry yes my department sets tones over 7/800 Trunked P25 Channel.
Sent from my iPad using Tapatalk
David_Oney
Former Unication Tech Support
Raceland, KY
Guys, keep in mind that if you are using the Delay N timer on P25 the unit will only alert on the first set of tones it receives once the Delay N has activated the unit only cares about receiving the voice traffic so if subsequent tones are sent during this time the unit will not decode them. Without looking at the file I cannot effectively diagnose the issue but this may play a part if utilized.
TFrank615
Springfield, Ohio
I’m pretty sure I’ve tried it and it only alerted on the first set. Is that for trunking or both David?
David_Oney
Raceland, KY
Just Trunking. Send me your file via email and I will take a look at it to see if I can help. If you could provide your Firmware and PPS info that would be helpful as well.
TFrank615
Springfield, Ohio
TFrank, if Dave has luck with your codeplug let me know please.
I tried what he said and it did work the first time, just want to test it a few times to make sure it’s working repeatedly. I’ll lyk
hfd26
So I've looked at my programming again and I have all my p25 channels set to selective call manual reset with delay n fuction off. On the channels I want just selective call alternative is disabled with all alert tones checked, on the channel I want to listen to the whole county alternative is enabled with alert tones checked. My talkgroup has alert tone set with the chirp tone. I still only get 1 alert tone to activate. When my dept is toned out we have 2 alert tone. The first one sets the pager off the 2nd sets the siren off. My minitor 6 will alert on both tones but the g5 wont. If I have the g5 on the analog channel it will alert both tones. For my p25 protocol parameters my minium short tone duration is 1000ms, my long tone duration is 5000ms, my minium gap between two digital is 500ms. The gap between two digital says on the right side of screen that it's the minium gap to determine two separate digital tone address in milliseconds. That sound like to me the gap between 2 sets on tones. My county dispatcher says there's a zero digital gap when the tones are sent on the trunk system. Could this be my problem as the g5 is looking for a 500ms gap between the tones.
hfd26
Also my g5 has firmware version v1.10 and my pps is the latest version also
TFrank615
Springfield, Ohio
Try putting your mode on Auto Reset. It seems to have been working on my pager that way. Auto Reset with Delay N Off
hfd26
I will give that a try. What do you have your auto reset timer set to
hfd26
Still not having any luck getting 2 two tone to activate on my pager. Had 3 calls yesterday and only the first tone set the pager off. It would be nice if we could set the minimum digit gap in protocol parameters to zero rather than 500ms. The pager doesn't even follow the vehicle I'd unless there is a gap between the radio transmissions not that that's a big deal but it not being able to activate 2 two tones kinda is.
TFrank615
Springfield, Ohio
Can I see your programming? Just too see if there’s anything I can tweak to help? Mine has seemed to be working well now. Tyler-Franklin@outlook.com
hfd26
Sure.I'm not near my computer now but I will try sending it later this afternoon or tomarrow morning.
