Multiple Antenna Question for 2M/70CM
I am a lineman for the county.
Here is one of the better guides I've found for doing really high spec installs on vehicles:
A lot of it is not radio related, but the same things apply. Follow this guide and you'll have a great installation. I've been using sections of this for many years.
ladn
You'll need a single pole double throw switch with a center off position. Double pole will be fine, but you won't use half of it. Might be easier to find the DPDT switch, though.
I use either a lighted switch (LED light) , or a separate LED as a power indicator. I usually pad the LED to dim it so It's visible, but not a distraction, especially in low light. The double pole variety are easier to find and I started using them when I had a 2-relay configuration.
ccg_ga
Cumming, GA
@mmckenna
SAE J1127 or SAE J1128 is my preferred choice. That's easy to find on Amazon. You want high count of fine strand conductors. That makes for a flexible cable that is not only easier to route, but will stand up to flex and vibration.
Got it, I ordered 30 ft of 8 gauge in red for the positive wire to have some extra if needed.
I figured I could pick up 5 ft or so of 8 gauge in black for the negative/grounds locally such as this marine wire from West Marine.
If you are going to fuse your system for 40 amps, then you'll need a 40 amp rated relay.
You want it after the fuse, the fuse is there to protect the wiring and everything attached to it, so a short jumper from the battery to the fuse, then everything goes after the fuse.
30 amps would probably be just fine for what you are doing, but you'd need to replace the 40 amp Maxi-Fuse with a 30 amp fuse. If you changed your system to 30 amps, using something like a Lind shutdown timer instead of the fuse would give you more options. It wires into the ignition and will automatically turn on when you start the engine. When you shut the engine off, you can set a timer for how long the radios will remain on. It's easy to wire a manual trigger switch to it to allow you to turn on the radios without starting the vehicle.
I was thinking if I can get a suitable 40 amp relay why not go ahead and wire it for 40 amps... I wasn't sure which relay to get looking either at the list that comes up via the Amazon link below
or possibly one of the 3 Bosch relays that comes up when you filter for 40 amps (0332019157, 0986332030 and 0986332040):
If that doesn't work then I was going to get the Blue Sea 30 amp Maxi fuse for the in-line fuse holder near the battery:
And then would this 30 amp Bosch relay the right one?
Yes, that will work, the one you linked to has several options depending on how many circuits you want to add. BlueSea makes good stuff.
I ordered the one I originally linked to. For whatever reason, I like the idea of the fuse block having the negative terminals as well.
I looked at the Lind timer but decided I'm already in this for about $800+ between everything so I'll just wire it up with the fuse systems for now. Maybe switch to the timer down the road. I'm usually pretty good about keeping an eye on things like making sure the radios are powered off when not needed.
There are two trains of thought to this. Both are valid.
1. Run the negative to a local grounding point. That uses the vehicle body as the return. If the battery strap for the negative terminal is in good shape and properly sized, there's no issue with this. The added benefit is that you are grounding your radios close by and that can solve some RF noise issues. It also saves you some money on wire. The existing vehicle electrical system does this.
2. Run an 8 gauge wire from the fuse block ground all the way back to the battery and ground to the body where the battery negative lead is attached. This gives you a return path that doesn't rely on the body. What it doesn't solve is issues with an undersized negative strap connection from the battery. On newer vehicles (probably not your Jeep) they have a hall effect sensor on the cable running from the negative terminal of the battery to ground. This is used to monitor current consumption of the vehicle and control things like alternator, auto shut off, etc. Bypassing that by running your ground all the way back to the negative terminal can create some issues. Usually the manufacturer will call this out in the manual.
I've never had an issue with grounding to the body. Those that claim it can create problems with corroded negative straps from the battery to ground are often people that do not maintain their vehicles and wait for things to completely fail before addressing them. I've never had that issue.
You —do— want a short ground for the radios to the body. This can prevent some RF interference issues. Relying on l-o-n-g paths to ground for radios, either through the antenna mount or the power feed is not a good idea. Long wires become good antennas and can either pick up noise or radiate noise. No matter which of the two options you choose above, run a short as possible ground strap from the radios metal chassis to a body ground point. I've solved some nagging issues with this. DC power ground and RF grounds are two different things.
Your fuse block has a negative buss, so you can use that for your power ground. Running the negative power lead for the radios to that is a good option. Just make sure you don't ignore properly grounding the radio chassis with a short ground strap.
Grounding the fuse block ground buss can use one of the two options above, either using an 8 gauge wire to the body, or run it back to the point where the battery grounds to the chassis/body.
See above. You need to consider your DC power ground and your RF ground. They can be the same thing if you do them right, or you can make them separate. Here's what I'd probably do:
1. Ground each radio to the metal box using a short strap from the radio mounting screw to the box. That'll work as a good RF ground.
2. Ground the radio box with a short strap to the vehicle. Sounds like that's going to be the windshield frame or roll bar. Make sure that the windshield frame or roll bar has a good connection to the vehicle body. Paint can get in the way….
3. Run the positive and negative power leads for each radio back to the fuse block.
Let's see if I understood correctly. I drew up (very crudely) how I understood everything below. The way I was thinking about it is pretty much exactly as you described just above. This is missing the wiring for the switch, more about that near the end of the thread.
88238
Here is how the radios are mounted now. I am finishing up the brackets I made for the IC-2730A.
88240
I could use these ground straps for the radios and run them either to the metal overhead console or maybe where the existing wires are hidden against the windshield under the molding or to the overhead console itself.
88241
And connect the ground straps to the radios in between the metal mounting bracket and the radio chassis:
88242
Check to see what the manufacturer recommends. Likely they have a fuse installed on the power leads. You don't need both fuses, you can use the one in the fuse block and run the power straight to the radio. I think you'll find that the radios will either have 15 amp or 20 amp fuses. 15 amps should be sufficient for a 50 watt radio.
Both radios indeed have a 15 amp inline fuse on both the positive and negative leads. Got it, so I can drop the in-line fuses once wired to the fuse block or does it not hurt to leave them in place?
I was thinking I could just get the 15 amp ATC or ATO fuses for the fuse block at the local Advance Auto.
Looks sufficient. The 'right size' depends on how long the cable run is. As the wire gets longer, the resistance increases and that will cause voltage drop. Keeping your power leads short is a good idea. Running the fuse block in the radio box is a good idea to reduce the length of smaller power cable runs. Rely on the 8 gauge wire from the battery to do the hard work. Keep the power leads that run from the fuse block to the radio short.
Ok, I will be able to shorten the run for the power leads thankfully provided the under-the-passenger seat mounting for the fuse block works out. Right now the power leads are extended by the 14 gauge wire out to the battery. That should effectively remove about half the total length from radio to fuse block. It'll just have to run from the radios mounted overhead down the passenger side roll bar and to the fuse block under the seat.
I looked around some more today for the single pole double throw switch but didn't find one that would potentially fit the OEM bezel yet except for this one from Daystar. This style will fit the OEM bezel, but it looks like it is just 'single pole, single throw'?
I did order the DPDT switch I linked to before, so at least I'll have that if I can't find a SPDT switch that works.
The center connection (Common) will be the connection to the relay coil. The other two connections will be used for:
1. full time power, that'll need to come off the battery or full time power source. Fuse it for 5 amps or so, just enough to run the relay coil.
2. ignition controlled power. That'll need to come from an ignition switched source, and also needs to be fused.
Once I get the relay I'm going to try and draw up a wiring schematic similar to what I did above. I'll post that in the thread to see if I am on base or not.
I need to figure out where in the Jeep to get the ignition controlled power from. I was thinking about the head unit, but I already am using that lead for an aftermarket head unit/wiring harness.
Is a 5 amp fuse fine for the ignition controlled power also or should I look that up in the Jeep owner's manual or other technical info I have?
I was thinking of using these in-line fuse holders as well for the relay/switch wiring:
Thanks for the link to the Caltran doc as well - I will give that a good read!
My concern is that some of those 40 amp relays look a whole lot like the 30 amp relays, and I'm not sure I'd trust some of the cheap Chinese sourced ones. Bosch is a reputable company, so if they have a 40 amp relay that meets all your specs, that's probably the way to go.
Those two radios probably draw more like 10 amps or so each, maybe a bit more, so unless you were transmitting with both at the same time, unlikely you'd have any issues with a 30 amp circuit. You'd still have some headroom to spare for future accessories. If you can do 40 amps, then go for it. If you can only do 30, I think you'll be fine.
Should be fine. Make sure you get one that's rated for continuous duty. These sorts of relays almost always are, but some larger starter solenoid type relays are only rated for intermittent duty.
Makes the wiring neater. I have a fuse block in my personal truck that doesn't have a ground buss, but I bought a separate one to use. I have them mounted side by side.
Consider mounting them on a piece of exterior grade plywood. I used a piece, spray painted it black, and bolted it down behind the rear seat in my truck. That makes for an easy place to mount everything and secure wiring. You can figure out what size you need, then assemble everything on your bench where you can easily get to it, then mount the completed product under the seat.
On that note, make sure you use high quality crimp terminals and a proper set of full cycle ratcheting crimpers. They'll do a good crimp every time. You can also slide some suitably sized heat shrink over them to protect everything. I can imagine that even under the seat of a Jeep can occasionally see some water/mud, so protecting everything you can is a good idea. Marine grade heat shrink works really well. It has a hot melt adhesive inside that flows when heated up and sort of glues everything together. Works as a great strain relief and helps keep water/corrosion out. 8 gauge is usually beyond the capability of most crimpers, so make sure you get good ones. Also, consider the copper crimp lugs rather than the tinned/insulated kinds. They do a nice job.
Label everything, even if you think you'll remember what it is later on. One option is to use P-Touch type labels and then slide a piece of clear heat shrink tubing over them. I do that on most of the wiring I do at work and in my own vehicle. Makes it easier to troubleshoot things down the road, and in my work case, makes it easier for someone to work on it if I'm not there.
Looks good.
That'll work, but it's kind of expensive. The braid is nice since it's really flexible. You can make your own with the outer shield from coaxial cable and some crimp on connectors. Even regular 14 gauge wire will work just fine.
Fuse connection usually have a bit of resistance to them, so there can be a voltage drop across them. Also, it's one more place you have to check if you have an issue. You are protected by the fuse on the fuse block, so it's not necessary. I'd leave them out. Probably a different flavor fuse also, so more spares you'd have to carry.
That'll be good. Less small gauge wire means less voltage drop. It also will make your overall wiring look cleaner.
I'd also suggest getting some split loom tubing to cover up any wiring you run. It does a couple of things:
1. It adds a layer of protection to the wiring.
2. It hides it well. You can look at the work and personal vehicles I've done and usually you cannot see any of the added wiring in the engine bay. My goal is to have all wiring hidden and the few places it shows, it's covered in split loom.
If you are going to use it in the engine bay, make sure you get stuff that's rated for higher temperatures. If you route carefully, you probably won't need it, though.
That is always a challenge. Consumer oriented vehicles don't make it easy. 3/4 and 1 ton trucks, especially the newer ones, as well as the special police package vehicles usually have wiring set aside for this. My F350's all had it already there in the cab.
You can find existing wiring or dedicated terminals on some cars, but you may need to check with the owners manual, service manual or if there is an upfitters guide for your Jeep. Fuse taps are usually not a good option as they can vibrate loose. One thing you can do on some vehicles is find unused circuits. I had a couple of Chevy Colorados at work and found the sun roof wiring taped off in the A pillar. Since the trucks didn't have sun roof options, I was able to tap into the unused wiring and extend it to the ignition sense lead for the radios. I found the sun roof fuse slot (unused) and put in a 3 amp fuse and I was good to go.
All it needs to do is drive the relay coil and an LED indicator lamp on the switch. 5 amps should be more than enough.
Yeah, that will work, but connecting it to the rest of the wiring is a pain. Generally I avoid using butt splice connectors whenever possible. They are a popular failure point and they can be difficult to crimp properly. One of these might look a bit cleaner and give you less issues in the long run:
Or this:
Most of it overkill for hobby stuff, but if you really rely on your radios, there's a lot of good methods and info in that document.
ccg_ga
Cumming, GA
@mmckenna
I think I have everything planned out at this point. The rest of the parts will be here on Saturday, so the fun begins on Sunday. More details to come!
Thanks again for your help!
WA8ZTZ
S.E. MI
Just a thought if you have not yet decided...
consider a MFJ 1414 dual band antenna on a Hustler RVM base.
Mount the base on one of the rear fenders.
ccg_ga
Cumming, GA
Thanks for the reply and suggestion. I ended up going with both of the Larsen antennas suggested in the thread and mounted them on the front fenders with a Laird 3/4" NMO bracket.
ccg_ga
Cumming, GA
@mmckenna @ladn
Ok, so everything is installed and wired up except putting the PL-259 connectors on the coax. I did some testing with the multi-meter before hooking the radio power leads to the radios (I haven't connected them yet).
I don't think the switch is working properly, or I don't have something right.
Here is how everything is connected right now on the relay:
30A 4-Pin Relay - Connected to a relay socket cap with 14 guage pigtail wires
Pin 85 - Relay Ground Coil - Grounded to a bare metal screw on a factory computer plug-in terminals near the battery
Pin 68 - Relay Coil Positive - Connected to the center pin of the DPDT switch
Pin 30 - Relay Common - Battery positive terminal via 8 guage wire and a Blue Sea Maxi fuse block w/ 30A maxi fuse
Pin 87 - Relay Closed Contact - Battery negative terminal via 8 gauge wire
Here is how everything is connected on the DPDT switch:
Switch Top Pin - Connected to factory fuse block terminal via a fuse tap that has switched power - 12V when on
Switch Center Pin - Connected to pin 86 on the relay
Switch Bottom Pin - Connected directly to the battery positive terminal with a 5A in-line mini fuse
- I couldn't find an always-on terminal on the factory fuse block so I just ran a direct wire to the battery and fused it
I get power at the radio power leads, but it never turns off regardless of the switch position. Here is what I tested with the multi-meter at the radio power lead connectors:
--- Vehicle Ignition Off ---
Ignition - Off
Switch - Center Position
Blue Sea Fuse Block - 12.21 V
MXT400/GRMS - 12.20 V
IC-2730A/HAM - 12.21 V
Ignition - Off
Switch - Top Position
Blue Sea Fuse Block - 12.19 V
MXT400/GRMS - 12.19 V
IC-2730A/HAM - 12.19 V
Ignition - Off
Switch - Bottom Position
(The top light on the switch illuminates in this position but the top light never illuminates in the top switch position)
Blue Sea Fuse Block - 12.20 V
--- Vehicle Ignition On ---
Ignition - On/Run
Blue Sea Fuse Block - 13.77 V
MXT400/GRMS - 13.77 V
IC-2730A/HAM - 13.77 V
Ignition - On/Run
(top switch light does not illuminate)
Blue Sea Fuse Block - 13.75 V
MXT400/GRMS - 13.75 V
IC-2730A/HAM - 13.75 V
Ignition - On/Run
(bottom switch light does not illuminate)
Questions:
1. Is this correct or do I have something wrong with either the relay or switch wiring?
2. The terminal that I connected the top switch pin to for switched power is for the vehicle radio and has a factory 10A fuse. I was going to use a 2A mini fuse in the fuse tap per the low draw for this switch, but can I leave the 10A mini-fuse in the fuse tap or if I put the 2A fuse in it will it be likely to blow?
3. The DPDT switch doesn't actually fit properly in the factory dash bezel so I am going to have to try and find one that will - but I will worry about that later. I'm guessing I probably won't be able to find another DPDT that fully fits correctly.
Thanks in advance for the continued help, I think overall it is close (hopefully)!
WA8ZTZ
S.E. MI
On an automotive relay, pin 87 is the normally open (N.O.) contact. On a 5 pin relay 87a is the normally closed (N.C.) contact.
Also, you say you have batt negative on pin 87 ??? Probably just typo errors.
Anyway, take the switch out of the circuit and test it with your ohmmeter. It may be defective,
especially if it is an auto parts store cheap offshore type.
AK9R
Super Moderator
Central Indiana
Google "Bosch automotive relay" and you'll get lots of wiring diagrams. However, those diagrams will get you in trouble if you aren't aware of the difference between high side switching (the relay is between the source and the load) or low side switching (the relay is between the load and ground).
However, we can walk you through this. Let's start with your switch. The wiring that you describe has power going to both the "top" and "bottom" terminals of the switch whenever the ignition is on, but only to the bottom terminal when the ignition is off. When the switch lever is flipped to connect the top terminal to the center terminal, the radio will go on and off with the ignition switch. When the switch lever is flipped to connect the bottom terminal to the center terminal, the radio will have continuous power.
Connect the center terminal on your switch to terminal 85 (or 86) on the relay. Then connect relay terminal 86 (or 85) to ground. Whether you wire it with current going from 85 to 86 or 86 to 85 doesn't matter as all you are doing is energizing a relay coil when you have 12 volts coming from the switch. Now, connect the 12 volt supply from your high current distribution block to terminal 30 on the relay. Finally, connect the radio's positive lead (usually red) to relay terminal 87. Connect the radio's negative lead (usually black) to ground. When the relay coil is energized, thanks to your connections to 85 and 86, power will flow from your distribution block through terminal 30 to terminal 87 and to your radio.
I agree, I think you have a bad switch, bad relay or your wiring is incorrect somewhere. Your multimeter should help you sort it out.
Also, double check that the switch works the way you expect it to. Sounds like you are right, but use your multimeter to confirm.
ccg_ga
Cumming, GA
@W9BU @mmckenna @WA8ZTZ - Thanks for the replies gents. It sounds like my issue may be due to pin 87 on the relay.
@W9BU The wiring on relay pins 86 and 85 is as you described. The switch center terminal runs to pin 86, and then pin 85 runs to ground on a bare metal screw. Pin 30 on the relay currently being fed by the 30A fused line from the battery positive terminal.
It sounds like the issue is how the Blue Sea power distribution block is wired in relation to the switch and relay (if I am understanding correctly). That is actually was I was thinking today while testing with the multimeter. Right now the positive/negative power leads for both radios are run directly to a Blue Sea fuse block that is fed with 12V directly from the battery positive terminal. This circuit from the battery positive terminal includes a Blue Sea maxi fuse block, which goes battery > maxi fuse block > Blue Sea fuse block/distribution.
The circuit that is wired to pin 30 on the relay also is from the battery positive terminal and includes a Blue Sea maxi fuse block as well (there are 2 total). It goes battery > maxi fuse block > pin 30 on the relay.
Pin 87 on the relay is currently grounded to the battery negative terminal as well.
So for pin 30 on the relay, should it say connected as it currently is - or does it need to run to the Blue Sea fuse block (not the maxi fuse blocks) positive terminal?
And on pin 87 - since it is currently grounded it sounds like that isn't right. Should it be connected the the positive terminals on the Blue Sea fuse block where both of the radio positive leads are connected (there are 2 radios I am running of the fuse block)?
I appreciate the help and please forgive my ignorance if either of the 2 questions above don't make sense - this is a bit more involved install than I have done before. I can draw this all up and post it if that is easier to understand.
I will do some testing on the switch and relay tomorrow as well to try and verify if either of them are bad. The switch is from Amazon and may very well be defective.
Thanks!!
I think this is where your issue is.
The + 12 volts to the BlueSea fuse box/distribution needs to be fed from the relay only.
It circuit should look something like this:
Positive side battery post —> Maxi Fuse block with 40 amp fuse. —> relay input pin 30.
Pin 87 on the relay —> to the distribution fuse block —> radio power lead
If you are feeding power direct from the battery through the fuse and to the distribution block, and at the same time feeding power from the battery to the relay and to the distribution block, the relay will disconnect the circuit, but the distribution block is still getting power from your battery via the other path.
ccg_ga
Cumming, GA
Good news - it works!!
I switched pin 87 on the relay just as you suggested, to the 12V positive line from the battery and 30A maxi fuse. After testing pretty much everything with the multimeter this morning for about 3 hours I finally figured out that the 30A maxi fuse on the circuit from the battery was blown. I'm not sure exactly when or what caused it to blow, but I put in a new fuse and had 12V at the distribution fuse block thankfully. The 4-pin relay tested out with no issues. I think the switch may have an issue, but it triggers the relay and I get 12V at the distribution fuse block in either of the switch ON positions (top or bottom).
I'll post the photos and more details up tomorrow once I finishing getting the wiring in the engine compartment squared away. I now know a whole lot more about how to use the multimeter to test different components of a system than I did before!
@W9BU @ladn @WA8ZTZ
88674
Awesome, glad to hear you got it fixed.
Excellent. You'll find those skills you picked up will come in handy in a lot of places. Often the first tool I grab at work is my multimeter. Trying to troubleshoot any sort of electrical issues without one is pretty much impossible. I keep a small inexpensive one in each of our personal vehicles and one in the camper trailer.
If you don't currently carry one in your Jeep, picking up an inexpensive one can be a great addition to your trail tool box.
krokus
Southeastern Michigan
This video shows a rack that was pretty popular with the TJ & YJ, but their website seems to be gone. They made some racks that the radio could be inside a pop-down type thing, similar to the sunglasses cubby in many vehicles.
They might be around, used, on Jeep forums
You could also check with Davey's Jeeps, in Ohio.
ccg_ga
Cumming, GA
Indeed. My electrical knowledge was pretty basic to start with so this whole project was a great learning experience. It's funny because the multimeter I was using today I have had for probably about 20 years. I must have bought it for a project on my first Jeep (also a TJ) and it was stuffed away in a drawer forever. It is an old Craftsman model, but it did the job perfectly. I will certainly add it to my tool kit for the trail.
