Multiple cross-band repeaters
Baul
Hi all,
Is it possible to set up 2 cross-band repeaters with same frequency sets whithout creating loops?
nd5y
Wichita Falls, TX
Unless the repeaters are far enough away that they can't receive eachother if the inputs/outputs are opposite and you don't use different tones on each channel they will lock up in a loop.
Otherwise it depends on how you configure them, how far away from the repeaters the users are and how far away from eachother the users are and what function you are trying to accomplish.
MTS2000des
5B2_BEE00 Czar
Actually it's possible. We did this about 15 years ago to create an "ad hoc" repeater where no local machine had coverage to support comms for a bike race. Both radios were "opposite" of each other and created an in-band repeater. It worked.
nd5y
Wichita Falls, TX
Then the radios must have been set up for one-way repeat.
nd5y
Wichita Falls, TX
OP might want to read these posts about crossband repeaters.
nokones
Sun City West, AZ
Hi all,
Are you thinking about connecting two repeater stations together that operate in the same operating band? When you state loops and same frequency sets it sounds like you are trying to set up something that operates in the same operating band. That type of operation is not cross-banding.
Cross banding means connecting two separate stations that operate simultaneously on different operating bands. I.E. A station operating in band "A" receives traffic and keys a station operating in Band "B" and transmit the same traffic, and vice versa, to allow the users operating on two different bands the ability to have interoperability with each other.
If two stations operating in the same band on two different frequency sets, by means of some type of an audio tie connection, would be "Multicasting". If multiple transmitters in different locations are operating and transmitting on the same frequency set and are keyed at the same time that would be "Simulcasting".
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
If crossband repeater one is programmed:
146.100 PL100.0<->446.100 PL100.0
And cross band repeater two is programmed:
146.700 PL100.0<->446.100 PL100.0 and
ALL users are on VHF, with their radios programmed:
RX: 146.700 PL100.0
TX: 146.100 PL100.0
It will function as an in band repeater IF there is adequate isolation/separation between the radios on VHF to prevent desense.
The down side is that if the UHF frequency is found, a malicious user could cause problems easily. I would probably use DCS rather than PL, as most hammy toys don't act on or use PL reverse burst. The triple squelch crash would fast become annoying as ****.
Moderator comment: TX frequency corrected.
kayn1n32008
Sector 001
Hi all,
If each radio was programmed:
VHF: 146.550 UHF: 446.100 with out CTCSS/DCS or the CTCSS/DCS was the same, then it would lock up the second you keyed up on either frequency, until the time out time expired.
If you set up a cross band repeater to link to inband repeaters(one on VHF and the other on UHF), AND both repeaters had repeater 'tails' long enough that the cross band repeater could hear, then you would get a continous cycle, bouncing between the repeaters, that would render the repeaters useless.
