Multiple radios on single speaker...
stang351
I'm about to add a 2M Yaesu to my scanner shack (just got my tech ticket!). How do you guys manage multiple radios on single external speakers?
rcvmo
Romulus, Mi.
I find the line output and connect that to a home-brewed mixer. If the radio doesn't have a line output terminal, then one is found on the hot side of the volume control or output of the demodulator/ squelch circuit.
rcvmo
kc8zdf
Michigan
Well I don't have any info for you except a spliter but the other guys on here have better setups then just a spliter. Congrats on the ticket.
N1508J
Not allowed...infraction.
How about a transformer?
In de olde days, I usta use a multi input primary or (secondary) transformer with a single 8 ohm primary or (secondary). In other words, get a transformer that has ISOLATED-multiple 8 ohm windings on one side, (which will serve as your inputs) and a single 8 ohm winding on the other side which will be for your speaker. Remember now, I said the multiple input windings MUST be ISOLATED inputs, NOT a multi-tapped 8 ohm coil...or else you'll blow any DC coupled audio output finals in the scanners!!!!
