Okay...my head is whirling around, probably because it's 5 'till midnight, or maybe because I've been digging around for 2 hours trying to figure out how to do this. I need help!
I'm running 64 bit Windows 7 with 5 instances of ScannerCast. 3 of those feeds are stereo, the other 2 are mono feeds. I'm using an M-Audio 1010LT sound card and have no problems with the hard wire connections to my computer. Where I'm having an issue is configuring ScannerCast in the Startup file so that they start right to their respective streams. I figured out how to get 5 instances in the Startup file, but I can't figure out how to change each one to be completely independent of the next. I've searched the forums here and they mention having to change your .ini file to associate with its own stream.
How do you do that???
I've even gone to K1PGV's website and found that of no help because I'm not getting the "Catch fired: Could not start server. Check Port and IP" error he describes. I also can't follow him when he says "start ScannerCast with the following command: ScannerCast foo.ini" Not sure what that means either.
I can get all 5 to run automatically from Startup, but the 2-5th incidences give me:
Error status from RR.
HTTP/1.0 403 Mountpoint in use
Content- Type: text/html
Retry: Retries connection (no further connection errors will be shown)
Cancel: Stops trying to connect to the RR server.
I then hit Cancel and get the following error:
Error 105
Connect to RR failed. No further connect attempts will be made.
Stop ScannerCast and try again.
I hit OK and then Stop Broadcast on the incident of ScannerCast. I have to manually configure the feed input and Feed to Send, and enable Stereo. Once I do that manually, I can start the feed and everything works great!
That's very much a pain to do. I figure by reading here that there is a way to have them start automatically and associate automatically, but I just can't figure it out.
Thanks in advance!
Error 105
Thanks in advance!
