MX to BNC coupler
CYUL
Montreal, Canada
Hi,
I have a handheld antenna from a Motorola HT. Are there any MX female to BNC male couplers? I've had no luck locating any .
Project25_MASTR
TX-COMU
Texas
Yes. Are they designed to be left installed? Not really.
The Waris series radios use a MX to BNC adapter that has a 3/32" mono plug sticking out the bottom. The Commercial series radios have some funky connector you will only see on them and the CP200d's sticking out of the bottom of the MX connector.
RFI-EMI-GUY
Hi,
I have not seen any. If you have an MX thread to BNC female. They are only good for puttting a BNC antenna on an MX or "analog" saber. They provide no return path for the shield so using as an adaptor for a mobile, base or test adaptor they wont work without bodging an RF return to chassis.
prcguy
Are we talking the Motorola MX radio as in MX-300 series or is MX a reference to the antenna thread type? I had a bunch of Motorola MX-300 radio BNC antenna adapters that plugged into the side connector on the radio. If that is whats being requested I'll go dig for them in the garage.
FedFyrGuy
Hagerstown, Maryland
CYUL
Montreal, Canada
Yea, this is an MX thread on an HT antenna, was wanting to connect it to another radio for receive only.
CYUL
Montreal, Canada
Here's an MX to BNC female. About half way down the page. Hope this helps.
Hi thanks for the link. This is actually for a Female MX (input) To male BNC coupler. From what I have seen and others have reported is that this coupler type is not available, unless you build it yourself.
