NAC 293
ecps92
Taxachusetts
Most got converted to P25 and are not mixed mode, staight P25 - but Yup, still tied into the dial tone networks :)
Would love to find a directory of the North East sites, there was one from the 80's on the net, for AZ/NV years ago
so the NRCS system uses a 125 watt Quantar repeater that will accept analog or P25 and is usually tied to a POTS line. Enven though it is a "FAA" repeater, it is open by default so other agencies regularly use. It definitely will not be what you are use to on the air bands. Think more along the lines grease monkies, techs work ILS problems, someone polishing a lightbulb. Or you have been listening to CBP/TSA. Like I stated before, they are wide open.
dave3825
Suffolk County NY
Makes me wonder if FAA Hartford in CT changed to P25 and that's what we are both picking up because its clear we are both receiving the same thing based on rid. I believe she gets a strong signal, and I am located between her and JFK and get a weak signal so it makes sense. Maybe someone with in range of Bradly could punch in the freqs and see what's up?
172.82500169.22500136.5 PLFAA Hartford EA63S
ecps92
Taxachusetts
In my monitoring experience the FAA went P25 10-15+ years ago
I've not found Hartford to be active, but TF Green in RI is on the same Freq
Marcy57
Long Island...NY
trying to remember your radio display
Grp could be TalkGroup, but most of what I see for the FAA is TG: 1
or these could be Radio ID's [RIDs]
Be Snarky back to the Children, they were rookies at this once before
and need to be more of an ELMER - that said there is nice feature here
on RR, that lets you flag someone to IGNORE - works rather well :)
This is how my display reads out different frequency than we are discussing
but that is the Icom R8600 readout...73,s Marcy
(what is the 6716994 mean?)...tks
dave3825
Suffolk County NY
I just looked thru my rids and I have a ton of 671xxxx labeled as seen on 408.2 nac 270 and they were Fed Protection Service. I live near fed court house and received without an antenna. While I don't have 6716994 logged, my FPS rid's do range from the lowest of 6711804 to the highest of 6755148. The 6716994 you logged fits right in. What's interesting is that your getting the rid's in the 671xxxx range with a 201 nac and the rid's I have in the 671xxxx range are 270 nac.
Marcy57
Long Island...NY
Dave I just posted that cause ecps92 "said he was trying to remember my display"
pertaining to 172.825 ...but tks for the info I,m not even sure what that number is
6716994..??..73,s Marcy
Marcy57
Long Island...NY
Dave I normally get 270 on there....just once in a awhile I will get 201 but not often just happened
when I did the screenshot 201 popped up!
ecps92
Taxachusetts
Looks as if your radio does display the RID [Radio ID] of each radio keying up.
Marcy57
Long Island...NY
I guess it does?, cause I was monitoring 170.550 NAC:167 and the numbers were rapidly
changing as the transmissions were taking place...another day another thing learned!
that freq. is vy active...(alot of different 337xxxx) 73,s Marcy
ecps92
Taxachusetts
Yes those numbers [RIDS] will change as each Radio user keys up
And keep in mind (lesson of the day) if you see anything other than 337xxxx for that favorite $167 agency, you are hearing it from other than NY
301xxxx - VT and Albany NY North
307xxxx - RI, MA, ME, NH
334xxxx - NJ
335xxxx - CT
341xxxx - Phil Area
dave3825
Suffolk County NY
334xxxx - NJ
335xxxx - CT
341xxxx - Phil Area
Is that on all freqs? Asking because I logged a few 301xxxx on 172.075 n167 and only entry in the db, is for Boston MA. They were logged in 2017
ecps92
Taxachusetts
Generally [some slight exceptions] buy yes
301xxxx would be radios assigned/issued thru the Boston Field Office, and since Boston handles, ME/MA/NH/RI - yes
Marcy57
Long Island...NY
334xxxx - NJ
335xxxx - CT
341xxxx - Phil Area
so whats? 338xxxx
ecps92
Taxachusetts
if and only if, related to a $167 NAC agency, this should be the Norfolk VA Field Office
Covering :
the counties of Accomack, Chesapeake, Eastern Shore, Norfolk, Northampton, Portsmouth, Suffolk, and Virginia Beach
so whats? 338xxxx
Marcy57
Long Island...NY
Covering :
653??? related to
ecps92
Taxachusetts
Please elaborate a little more
RID of 653xxxx or NAC of $653 ??
IF RID we would need to know what Freq and NAC - At this time there is no common
uniformity for RID's with Federal agencies, only within Federal Agencies do we see "some" patterns
The NAC of $653 has been observed in use by multiple agencies
Two in particular:
NAC $653 has been seen as the input NAC for the BATFE NET-3 Repeater
NAC $653 has also been seen/used on the Federal Interop Channels
653??? related to
