baddandy23
what is the difference between narrownband FM and just FM??? My 96 does only FM but my new 246T does narrowband also... is there any bennefit with the narrowband? thanks. :?
milf said:Hope this doesn't confuse you even more.....
. . . . The newest are beginning to allow for the SNFM spacing, but the Radio Shack scanners do not actually call it NFM, much less the right name which is SNFM,.... . . . ..
milf said:The first steps to going to P-25 digital ready in many cases, including the Fed freqs.. is to go to SNFM spacing.... as i siad.. its all part of the big picture...![]()
baddandy23 said:what is the difference between narrownband FM and just FM??? My 96 does only FM but my new 246T does narrowband also... is there any bennefit with the narrowband? thanks. :?
the IF on the 96 is the same as any other radio - it is NOT significantly more narrow than previous scanners
pro92b said:the IF on the 96 is the same as any other radio - it is NOT significantly more narrow than previous scanners
Wrong - I know this from the service manual. It is as I said.
Are you saying the 96 DOES have a mode designed for 2.5 kHz deviation FM that switches to a narrower IF and/or more audio gain?
pro92b said:Are you saying the 96 DOES have a mode designed for 2.5 kHz deviation FM that switches to a narrower IF and/or more audio gain?
No, the PRO-96 does not have switchable selectivity in the IF. It uses a Murata CFULA455KF1Y filter. It has only four elements (economy type) and a -6 dB bandwidth of +/-6 kHz.
The PRO-93 and PRO-95 use a Murata CFU455D2 filter, also four elements but with a -6 dB bandwidth of +/-10 kHz. Most scanners use the +/- 10 kHz type filter. Those with selectable modes (NFM vs FM as Uniden calls it) will have 6 kHz and 10 kHz filters. The BC780 schematic shows the two filters selectable by a CMOS bilateral switch.
Professional radios will use better filters having more elements for superior stop band rejection.
I can post the filter datasheets if you are interested.
