As of Oct 7, 2022 the Lake Mead 170.050 frequency that is normally very active has been silent. Have they moved out of the VHF band or transitioned to a Trunked System ? Anyone have any information on this?
Is "700" the unit/console ID that displays or a verbal call sign or both?The base still IDs' as "700" and references were made to the Hemenway launch ramp and the usual mobile ID's in the 400 series were heard. No question about it. It is the LMNRA.
The call of 700 is the callsign assigned to the dispatch center in Las Vegas that they have used for many years. It's verbal and often heard when field units call the dispatch center.
The new frequency appeared in the database yesterday along with the primary NAC. It's a strong signal heard in Kingman with an outside antenna. Many years ago the Grand Canyon NP switched from an analog system to P25 and their radio signals can sometimes be heard in Kingman.Thanks AZMONITOR, the Park Ranger traffic from 170.050 has moved to 169.6250 P25, I am now hearing them again.
After the changes have been sorted out the database will need to be updated.
A second NAC code is also appearing with the new frequency of 169.6250 and it is 293.
I will follow your suggestion AZMONITOR as I am located on top of the hill overlooking Lake Mead. I have a very strong signal on the 169.6250 frequency but often miss the reply on the mobile side. I am monitoring just the single frequency and have reduced the delay time but still seem to miss some traffic which leads me to think I don't have everything I need programmed in yet. Some days there is not much activity so may take me a while to do the search. F.Y.I I have two BCD996xt's and three BCD996P2's at two locations so I will put them to work!
