National Park Service Rangers
es93546
A Member Twice
Right Side of CA on maps
It would likely take a spy satellite with all their rumored resolution to see some of these remote repeater sites. By the way, both peaks I mentioned have small solar panels as well, but they are black and don't show up on Google Earth.
Teotwaki
SoCal
I know of a couple of repeater sites up here on the Inyo where I know they are there since I've climbed both peaks. I've also used these repeaters for the 18 years of my career in the eastern Sierra. I could not find any indication of a repeater's presence on Google Earth. The vaults at these sites are tiny, perhaps 2' x 2' or 3' x 3' and 2 1/2 to 3 feet high. Both are painted a very light green color, which may not allow enough contrast to be seen on Google Earth. In these two sites that is as it should be as both a prominent peaks in very scenic areas. The two peaks I speak of are Mt. Warren and Olancha Peak. Heck, Olancha Peak has an Inyo and Sequoia repeater up there, but you have to be nearly on top of them on foot to find them. The antennas are also stealthy.
EDIT: The antennas on Olancha Peak don't have any type of a tower device, their mounts are drilled into rocks. Good old lag bolts and shields. The antenna at Warren is mounted to the little vault up there.
Good point. In Cleveland NF the repeater at Sitton Peak is in a small above ground cabinet that isn’t visible in Google sat images
