ncc rebanding
de784
Delaware
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID RAZR Build/9.8.2O-72_VZW-16) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Renaming will start today in Ncc and finish in Sussex April 6
de784
Delaware
Rebanding sorry
h8tdigitalradio
Six Feet Under
Hello,
CCh 853.2125 is online. GRE PSR-500 tracking fine using 800 MHz Rebanded Tables. Note: While the CCh is 853.2125, the old voice channels are being used.
h8tdigitalradio
Six Feet Under
Hello,
Uniden BCD996T/BCD396XT working OK with 853.2125 CCh. Next, lets see how the PSR-800 handles it. Fascinating with new CCh, the old voice channels are used.
Just finished reprogramming scanner for NCCo Police Feed.
Audiodave1
Chadds Ford, PA
We are not technically re-banded yet, they just added a channel. One step @ a time.
My 785 is tracking the system just fine with the new CC added...for now.
h8tdigitalradio
Six Feet Under
Yep. To be on the safe side, programmed my receivers with the Rebanded Bandplan just in case. Is UT showing 851.2375 as Alternate? Trunk88 shows the Frequency Color as ACCh.
pjc
Wilmington,Delaware
Home Patrol and rebanding
Don't have much tech talent just push buttons on my homepatrol. Any suggestions on how to get homepatrol up to rebanding speed?
whatevah
Wilmington, DE
my Trunk88 CC decoder is showing 851.2375 853.2125 as new frequencies. The old band is still being used for the voice comms though. 853.2125 is the primary control channel, as previously posted. I'm going to let it run for an hour or so and see what else it sees and what zones they belong to.
ok, let it run for 2 hours, all it found was the 2 I listed above. The neighboring zones it reports (2,4,6,7) all still have the original frequencies (of course, zone 4 is Wilmington and was already in the 85x range.
here's everything associated with Zone 1, copied raw from Trunk88.
; channels: bandplan channel number, physical channel number, frequency, time limit, BSI, control channel, comms count
;;[Zone 1]
Connect Tone = 138.46
Neighbour = 2
Neighbour = 4
Neighbour = 6
Neighbour = 7
; 14 channels
9, 0, 851.2375, 0, 1, 0, 0
88, 0, 853.2125, 0, 0, 2, 0 ; PCC
619, 0, 866.4875, 0, 0, 0, 189
622, 0, 866.5625, 0, 0, 0, 158
641, 0, 867.0375, 0, 0, 0, 176
649, 0, 867.2375, 0, 0, 0, 180
659, 0, 867.4875, 0, 0, 0, 178
668, 0, 867.7125, 0, 0, 0, 184
669, 0, 867.7375, 0, 0, 0, 180
695, 0, 868.3875, 0, 0, 0, 180
708, 0, 868.7125, 0, 0, 0, 168
717, 0, 868.9375, 0, 0, 1, 0 ; ACC
718, 0, 868.9625, 0, 0, 1, 0 ; ACC
749, 0, 866.7250, 0, 0, 0, 180
h8tdigitalradio
Six Feet Under
Hello,
There is a mix of rebanded and unrebanded VC's being used. Using the Standard Rebanded Band Plan, scanners are tracking it fine. No issues.
Audiodave1
Chadds Ford, PA
PJC,
Grab the home patrol online update Monday PM update (I believe) and you should be good to go if things are operating as they are today.
I am unsure if the system will cut over to completely/officially re-banded between now and then or not. When it does I will get the database update completed ASAP. Being it's a holiday weekend and I have family in town will do my best keep up with the changes in real time.
Dave
h8tdigitalradio
Six Feet Under
Trunk88 shows 4 Rebanded VC's:
851.4875 MHz
852.2375MHz
852.7125 MHz
852.7375 MHz
Alternate CCh:
853.9375 MHz
Also, a new VC:
862.7125 MHz
