Small world indeed! Terry Buff and I both used to work for Triangle Comm and now he works for Wireless Communications. There was a tower in Kernersville for the SHP comm center that was located there, but it and the center have been long gone since the Greensboro comm center was completed in the 50s. In regard to the tower at the Salisbury comm center, it's the source of the call sign KIH781 and it's still very much in use.
The SHP transmitter sites range in power from about 350 down to 100 watters, depending on the site. The older Motorolas (Micors) and GEs (MASTR Pros) still in service are almost all 330-350 watters and are tube finals. Up until the 80s, Williamston, Elizabethtown, Raleigh, and Greensboro comm centers all had the option of using the "high power" transmitter: 3KW on 39 mHz. The high power was used because they didn't have remote receiver sites at all when the 3KWs were put into service, and a lot of the dispatching was done "in the blind", just as it had been done on the AM system. The troopers would stop somewhere and call the station by phone when the car radio couldn't make the trip. When the FM system was first put into service, there was one frequency state-wide, and only a few cars had transmitters, so it was a while before there was what you'd call a two-way radio system for the SHP. The 42 mHz freqs didn't come along until the late mid 50s.
The 3KWs have all been removed, but they were built by Gates for Motorola, and had two humongous "toobs" cooled by two of the most beautiful machined cast aluminum centrifugal fans you can imagine. Those mamas used a pre-Twin V Motorola mobile unit in cabinet 1 as an exciter to feed a 250 watt transmitter in cabinet 2, and that was the exciter for the 3KW mutha in the 3rd cabinet. The power supply for the big mamajama was in the 4th cabinet. They could elect to either use the 1/4 kilowatter as the transmitter, or flip the switch and have it switch the antenna relays to the big dog and let the 250 drive the 3KW instead of feeding the signal directly to the antenna. The receiver was in the mobile unit.
In the early 60s, the state got a second channel to use as a car-to-base frequency, and that required 2 channel radios, sorta. Channel 1 was 42.62 and car-to-station (ch 2) was 42.78. The radio was configured with ch 1 as 42.62 RX/42.78 TX, and ch 2 was 42.62 simplex, so the receiver was really a 1 channel unit. Soon after, they got two more freqs, and the "new" GE MASTR Pros had 4 channel transmitters and 2 channel receivers. When the SHP divvyed up the state into radio zones was about the time I first got involved with SHP radio. Many of the cars still had the old Motorola Twin V low banders that had been upgrade to two channels a few years earlier, and those cars couldn't talk to the cars in the adjoining radio zone, so it didn't take long for the new radios to get distributed.
There's just not enough space and time here to tell the whole story, but there ya have a part of it.
