Need a Blank/Default VHF CDM1550-LS Codeplug
K4APR
Chesapeake, VA.
I have a VHF CDM1550-LS I'm trying to program for a friend. If I make any changes to the codeplug I read from it, I get the usual field errors. If I start removing the errors, eventually I get more errors, but they throw the error of "Field not found". Basically I'm looking for a factory default codeplug that I can write to the radio and "start over" with.
Thanks!
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thanks!
I have posted this info many times before, but...
You already have what you seek.
Look in the samples folder where your CPS program files reside on your computer. There is a sample codeplug for each and every model number of the Professional Series. It is a single personality codeplug ready for your customizing.
Search tags: The Professional or Waris
Series of radios includes:
HT750 HT1250 HT1550
EX500 EX600 EX560 EX650 PR860
CDM750 CDM1250 CDM1550
HT1250LS+ CDM1550LS+ CDM1550LS
It may be helpful to search using wildcards.
If someone asks a question about one model,
the answer usually pertains to most, if not all.
They are all programmed with HVN9025 CPS.
Channel One
So create a 1 channel simplex codeplug in the software, and write it to the radio.
Like Steve says, this is pretty much what you are going to find, when you look at the sample codeplugs that came with your software.
SteveC0625
Thanks! I don't frequent this forum much anymore, so I'm sorry if I missed you posting this in the past. I'll check this out when I get home.
That's why the forum has a search function. I just looked back and found a thread in which I answered the same question less than two weeks ago.
