Tim-B
- Joined
- Nov 17, 2016
- Messages
- 542
- Reaction score
- 78
Does anyone know where I can get a the tool needed to remove the retainer ring that screws down over the BNC connector on an ICOM radio?
What do they call those things in proper English? I am trying to find a larger one to remove an antenna connector from a Syntor X9000. I was about to cobble one up from pipe but with proper translation, it must be a common type nut.I bought something similar to this but it doesn't fit all brands of radios. They give approximate dimensions so maybe you can measure the diameter of the nut and see if its close.
Plumbing supplies sounds like a good bet. I see something at Lowes that is correct shape. No idea on size.Last time I bought some there were simply referred to as an "X tool". E-bay and Amazon usually have them.
Kenwood service manuals refers to it as a "nut wrench" or KENWOOD part No. : W05-1123-00
I've also seen them referred to as "packing nut wrench", but searching on that mostly gets you plumbing tools.
I never thought of 90 degree needle nose pliers. I will pick up a set of those too. There are a number of things I could use those for.
Sometimes called antenna spanner tool....
I believe those are 4-way water shutoff keys, and would not have the required design at the ends.Plumbing supplies sounds like a good bet. I see something at Lowes that is correct shape. No idea on size.
Absolutely! You'll find them at www.icantthinkofthenameofthethingamajigIneed.com!"Do you guys know where I can find an amalgamated diversified discombobulator?"
