Anytone Need advice on how to program a anytone up-878 dmr for public service monitoring
wc8i
Marion, Ohio
Hi guys I hope some one can tell me how to program my anytone 878 dmr radio to monitor a police dmr frequency, I have them programmed in my scanner and since I don’t use dmr on the armature bands much I would like to use it to listed to a local dmr frequency which is police, I turned on the professional mode in the 878 in the program I no the color code and slot but from there I’m a little lost, I don’t think I would half to use the zones, anyone done this that might be nice enough to tell me the steps?I ask on some of the dmr sites and all I got was negative comments, everyone stay safe and god bless bill wc8i
alcahuete
Southern California
Put in the frequency, then turn on Dual Monitor (Promiscuous Mode). You don't need to do anything else. With the Anytone, you don't even need the color code to monitor, but you can put it in if you want.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Don't turn on the Professional Mode... leave this setting on Amateur. Professional Mode would limit your ability to make any changes or call certain functions from the keypad. ("Professional" as in "Don't want the employees fiddling with the radio settings")
chief21
Once you save a frequency to a memory channel, you'll need to add the memory channel to a zone or you won't be able to recall the channel. (It's much easier to use the programming application if you're not already doing so.)
KE5MC
Lewisville, TX
I assume alcahuete is talking about VFO mode and I would add to make sure digital has been channel type selected and showing DIG in the upper left corner. Learned promiscuous mode works in VFO mode from a thread I was in the other day.
alcahuete
Southern California
Either or. It works as a channel or in VFO mode. As long as the frequency is in somewhere (DIG, as you mentioned), promiscuous mode will work.
