Need EZScan software - Whistler links down
Hi,
I went to the Whistler site and all the links for downloads appear to be dead.
Looked at all the sites for scanner downloads, and @jgriffter appears to be correct, however, the web pages are still alive but all the download links are missing from the bottom of the pages.
tvengr
Well Known Member
Baltimore County, MD
Picked up an RS 668 with the factory upgrade and i am trying to get a copy of EZ Scan for 1080 to program it.
What is the boot version? It will be 2.0 if it has the official upgrade. If it doesn't have the official upgrade, a firmware update can brick the scanner.
buddrousa
If you remember the Different Software Versions were Required For Different Database Versions not sure if the Firmware was tied into this also does not matter until you can update the Database with the Software again.
tvengr
Well Known Member
I didn't see where he was asking about updating firmware,
Sounds like the OP just purchased the scanner. I was giving the OP a way to know for certain if it has the official upgrade before updating firmware when and if the links return. It's safe to update the database. If the scanner does not have the official upgrade, updating the firmware can brick it. The boot version info comes from the author of the hacked firmware. That only affects the scanners eligible for the Whistler Legacy Upgrade (PRO-668, PRO-18, and PSR-800).
jgriffter
Cmjonesinc - thank you! Worked just fine for me.
I bought the Pro668 and it recently had the Whistler factory upgrade according to the previous owner. I haven’t tried to update the firmware since links are down - I mainly wanted to get the software to load up a couple of lists. Seems to work ok but pretty weak on P2 compared to the SDS. I’m spending some time figuring it out compared to Uniden.
Thanks everyone for your help. This is a great forum!
uneek156
Thurston County, Washington State
Does anyone know the status of the Whistler website? When will they be back online with options to download. I've emailed them 3 times now and have not received anything back.
Aradalien
Does anyone have the cpu and dsp updater for 7.4 and 3.2 eu as all links on whistler for firmware are down and ezscan gives an ssl error.
wa8pyr
Lead Database Admin
Ohio
If you need EZScan software, check Archive.org (put whistlergroup.com into the web search bar). Go back to 2023 and look there. I just downloaded v3.45.0.7 for my TRX-1 that way.
KevinC
32D2T/957.282
I'm everywhere Focker!
Or just DL from the Whistler group website...
uneek156
I have the software, I just need an updated library. Our local 911 just switched last week to digital. The list I have doesn't have the new updates.
uneek156
I have the software, it doesn't have the new updated library for my area as our local 911 switched to digital last week.
