Need help programming an ICOM 7010T
rja1
Enfield, NH
Got this cause it's compact & I'll use it for a 2 Meter rig and to listen to a statewide trunked system. For the statewide system, I've loaded all the voice channels & ACC's into one zone 1 & will load 2 meter repeater frequencies & some simplex frequencies into Zone 2. Have the same setup in my R30 & it works GREAT! Hears more sites than any of my 7 Unidens, including the SDS100. With this rig, I shouldn't have to worry about getting popped for violating VTL section 397, here in the less than wonderful state of NY.
I've loaded up 19 voice & ACC's in the 7010T, but cant get the rig to scan through them. I go to the Menu> Channel Scan> Scan Start/Stop >SCROLL TO "on" > OK, & get Scan Start / Stop failed. I programmed two of the side buttons for channel up channel down & they don't change the channels. The only way I can do that is to rotate the knob between the antenna & volume knob.
Any help would be greatly appreciated.
Thanks,
Bob / rja1
W2GLD
Southeast Michigan
You need to add the channels to a Scanlist in the Memory CH section and then activate that list from the radio’s UI. Also, highly recommend that you upgrade to v3.6 FW if that radio is running anything other; which also requires CS-F7500 v2.8 programming software as well.
