Need Help with Astro Mobile CPS
spanky192
Crowley, TX
I am trying to help a small fire department with programming their XTL radios. The guy that programmed the radios before put an ASK write protect on all their radios. He has since got of the business. I have ASK for both systems in the radio and I can program them but they are asking if I can remove the write-protect so that they can program the radios themselves since they were able to buy the software and cables. The only problem is they do not have access to ASK as I do. I have a lot of experience with APX CPS but not with Astro. I am not wanting to use an ASK removal program that I have read about online. I just want to know if I can use Astro CPS with my ASK to remove the write protection.
W0JJK
Here is how we do and it works. You need soft key and advanced key.
Step 1-Load Advance System Key
Step 2-Read Radio
Step 3-Tools-Password-Read/Write Password, this were you remove code plug passcode if used.
Step 4-Modify Permissions-Uncheck all three boxes, Click OK
Step 5-Tools-Set Owner System ID
Key Type-Advanced System Key
Owner System ID- select correct key number of the system.
Click-Disable Write Protection
Click Set
When this process is done, Close CPS, remove Advanced Key from Computer.
Step 6- Open a new CPS session, Load Soft Keys that match the systems in radio. Read the radio and now you can program them with soft key.
spanky192
Crowley, TX
Step 2-Read Radio
Click Set
thank you. I will try this tomorrow.
