Need Help With Programing A 2096
echo174
hagerville
Hello All I Might Have A Problem.ive Checked All The Threads On The Sight But None Comes Close To Mine So Im Lost.ok Ive Bought 20-047 Cable From Radio Shack With The Mono And Stereo Plug.i Dont Know Whitch Plug To Use.the Cable Is Usb To The Computer And Im Useing A Hp Pcm7263w Computer That Is Loaded With Win Xp But Its Not The Home Edition.i Think Its The Prof.edition I Downloaded The Win 96 Months Ago And Didnt Know It Had 30 Day Use.so I Bought Win 96 But Im Waiting For The Key Code.so Just Playing Around I Down Loaded Scan Cat Mmm Its Not Easy To Use In My Eyes Its Mostly Made For A Uniden Scanner.but It Did Have Pro 2096 On The List When I Pressed Auto It Just Gave Me Port 4 And 7 Open I Have No Idea What Port That Is. Im Useing Usb Like I Said I Thought It Would Pick Up That Automatic.
Ive Even Down Loaded Trunk Star Xlt And It Dont Work With Pro2096 So My Big Question Is Do I Use A Diffrent Computer Or Cable And Now Im Wondering That I Just Spent 30.00 On Win96 And My Computer Is The Problem If Antone Can Help That Would Be Wonderful
turbo77577
Fort Wayne,Indiana
do you have a gray cable, do you have a serial port on your computer? win96 is the best program to use. scan cat lite should work but not as good.
lowboy654
DB Admin Member
Northwest, WA
Let me just say i have win96,97 and scancat lite and as far as i can say scancat is a pain in the butt but it can program my pro-2051 so i still keep it on my computer
TES
America's High Plains
lowboy654 said:
thats the wrong cable you need this one.well it is there new usb one but some of the people that i know have had problems with it.if you have a rs-232 port i would get this one, I believe that is what it is called it should be blue and not the port for your monitor
http://www.radioshack.com/product/index.jsp?productId=2102526
The Radio Shack 20-047 cable is fine. It's endorsed by Don Starr himself in this thread: http://www.radioreference.com/forums/showthread.php?t=35021
echo174
hagerville
Thank You Alot All The Info Realy Helped I Sat Here Playing With Scancat Light Plus Demo And I Finaly Got It To Read The Radio The Bad Thing Is I Cant Download To The Radio.i Still Have Not Got A Email From Win 96 With The Key Code See When Win 96 Asked About My Add.i Still Left It As My Home Add.not Email.has Any One Done This And How Long Did It Take Them To Send The Key Code Thanks Again
Robert
Pro-2096
Aor-2500
Dx-403
Pro-83
DonS
Franktown, CO
Your Win96 registration key was sent to the email address associated with your PayPal account - it was sent as soon as the PayPal transaction was completed.
lowboy654
DB Admin Member
Northwest, WA
Like I said some people i know have had problems with Radio shacks new USB cable and that is just a fact, I my self have not used one I am just stating the facts as I know them, Now the above facts given it is most likely issue with there computer and is most likely just that.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
lowboy654 said:
Like I said some people i know have had problems with Radio shacks new USB cable and that is just a fact, I my self have not used one I am just stating the facts as I know them, Now the above facts given it could be a issue with there computer and is most likely just that.
I have helped correct problems with this new 20-047 cables. A simple correction in the PC Device Manager solved the problem. These problems were not the fault of the cable or cable drivers.
Edit: by echo174"With The Mono And Stereo Plug.i Dont Know Whitch Plug To Use" Use the stereo as per the pdf.
echo174
hagerville
Ok Everyone Ive Got It Running Full Now I Wasnt The Computer Nor The Cable It Was The Stupied Operator (my Self) Lol.i Wasnt Paying Att. To What It Was Telling Me I Was Making A Simple Task In To A Major Problem.win96 Is Pretty Good Program.i Still Have Some Questions On The Win96 Programing Ive Noticed I Cant Program My Other Vscan Folders,and Also What Are The Extended Freq.i Do Know By Reading Some Of The Threads That It Will Do Mil.a/c Ive Done That And It Works.so Know What Else Can We Do With It.
And Thank You All And Thank You Don For The Key Code
fmon
Eclipse, Virginia
Glad you got it working.
For Win96 V-Folders and other "Extended" features.
1. Hovering the mouse over Refresh or Commit should provide info as to what either will do with respect to other associated operations available.
2, Other extended frequencies available are the scanner will tune down from default 25.0000 to 17.0000 MHz and from default 806.0000 to 764.0000 Mhz. The latter will not provide for trunk scanning in the 764 range but some users are reporting that conventionally, they are listening to new trunking systems evolving n this range.
Win96 is unique in both features above, plus it provides the user to set up to 6 extended tables for either Mot 3600 CC and/or 9600 CC operations. And the new 1.53 version allows the user to set table step ranges below default 6.5000 to 1.25000. This alone saved our butts here in Virginia on a new statewide MOT 9600 VHF system, for we found a previously unreachable step setting of 2.5000. Don worked on it overnight and provided the solution.
BTW, these ranges were verified using Mike V's latest version PRO-96COM utility for MOT 9600 CC systems. His previous version would not function with this system because it depended on the CC providing SysID data to the scanner. Mike worked overnight and provided a fix for this condition. Bingo, we were able to log tower data which listed the step size. This gave Don what he needed to do to solve the problem by using Win96. This is well beyond what the scanner buttons or other software will provide.
All for 30 bucks and this was without Extended freqs, Web Import and now, "Extended step" ranges plus the many other improvements to the overall operation of Win96.
I should also--while on this soap box--give credit to rfmobile, Rick designed a Pro96Dump utility which first pointed to the possibility that the 2.5000 step size existed in the Virginia system. We've had a lot of help, with very little cost.
