Need help with RR frequencies
mrova
Chesterfield, VA
Howdy.
I've got the Grecom PSR500 scanner and I've loaded most everything I'm wanting from here around Central Virginia. What I'm having trouble with is finding the railroad frequencies to load into a scanlist. I'm using Win500 software to load off of Radio Reference, but I can't figure out how to find the RR frequencies going through Win500.
Not a problem to go to Radioreference.com and see the railroads listed in the database, but they're not there when going through the Win500. Help? Please? And, thanks! - Steve
mrova
Chesterfield, VA
Rivardj, thank you so much for that! I never thought to put 'state' on 'nationwide'. Easy peasy! Thanks again! sv
Swipesy
Northern Ohio
Mrova, don't be disappointed when you don't hear a lot of train traffic on the PSR-500. I have been a train watcher for 20 years and can tell you that the 500 is not good for this task. You will hear some traffic but the scanner misses much. Those of us that watch trains as a hobby use dedicated VHF or much older generation scanners for trains. The PSR-500 is great on digital trunked systems but not good on the 160 band.
jaspence
Michigan
I have the RS Pro 106 which is the same scanner, and GRE scanners have actually been know as too sensitive and prone to overload on VHF. This can also create a problem, and even a nearby VHF transmitter not on Rail frequencies could be the cause. The other issue that is slowly being introduced is the move to NXDN by the railroads. Same band, but digital mode that the 500 and 106 cannot decode. The newest Whistler scanners can handle NXDN and DMR which is very popular.
mrova
Chesterfield, VA
Thanks for the info Swipesy! My primary interest is when I'm in the area of the trainyards around here, maybe I'll pick up something interesting, but more than that, I try to get to my hometown of Danville, VA when the NW611 is rolling through (currently having maintenance done in NC), and then when it makes it's trip up this way to Old Town, Petersburg, VA.
I've got an old bearcat 180 that should cover that pretty well, shouldn't it?
thanks again! sv
mrova
Chesterfield, VA
Thanks jaspence for that info too! I'll have to keep that in mind. I don't suppose another scanner would be much of an issue with my wife?!!? :D
