LMRN Programming onto Uniden 996P2 with FreeSCAN
ve1sef
Halifax Regional Municipality, NS, Can
Try setting the system and site quick keys to 1. All need to be the same. If you set the sites to different numbers, the site is looking for the corresponding system with that number..
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I'll throw this out there. Try increasing your Hold Time from zero to +5 seconds.
EVANTYSEVEN
Wrecker
Bolton, Ontario
Hey guys.
Tried both your suggestions, still have no reception on the radio. I was sitting with one of my buddies and his radio was chatting away crystal clear. Even after I left mine still sat silent.
I ended up biting the bullet, I’ve ordered a Mini USB 5 pin to RS232 Serial cable so I can hopefully Master/Slave clone off his tomorrow.
Once that’s done I’ll likely download the scanner’s programming and compare it to mine to see where I was wrong.
In the mean time if anyone else has further suggestions they’d be greatly appreciated…
Thanks!
ve1sef
Took another look at your screenshots. Noticed on page 2, that there are 3 talk groups locked out.
Those wouldn't be the areas your trying to listen too?
Another observation, on page 4 I noticed you entered LCN numbers.
Try changing those all to 0, see what if any difference that makes.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
Hey guys.
Thanks!
Why don't you read the friend's scanner (assuming it is a 996 or 325) into Freescan then upload that programming into yours?
I suspect it is likely simulcast distortion, but if your friend has the same scanner, same antenna, same location and his works then this is how you would be sure it is not your programming.
EVANTYSEVEN
Wrecker
Bolton, Ontario
I didn't expect the scanner to work if we were sitting beside each other - we work different sides of our town, there's no way they're interfering. Also, my friend is the same as me - his scanners allow him to make money, no way he'll let me take it out of his truck to Download. Like I said earlier, gonna try a Master/Slave clone tomorrow and then download and review.
The Talkgroups I have locked out are the ones I dont want to listen to. The most important talk group for my service area will be 2055, which I've kept open, but I want to scan the others too.
The LCN numbers I believe are just the order which the site frequencies are listed, I doubt that will change any function.
EVANTYSEVEN
Wrecker
Bolton, Ontario
You will need to enter the band plan MANUALLY in the scanner. Using the software won't work... I had the same issue.
Does it make a difference? I checked the band plans in the scanner and they all look the exact same as they did in the program. To resolve curiosity, I will go into the scanner later and manually re-enter all of the King city site band plan and see if it makes a difference.
EVANTYSEVEN
Wrecker
Bolton, Ontario
So more bad news. For some reason his scanner and my scanner won’t master slave clone. I just keep getting errors.
Starting to think it’s not meant to be - I either need to pay someone to bring my scanner to the guy who won’t answer my phone to program it or give up on scanning MTO.
Is it possible that the scanner firmware needs to be updated and that would be causing the issue? I’ve never updated firmware on any of my scanners
Anyone have any more ideas before I give up?
ve3tej
London, Ontario
There's been a few people with bandplan issues. You may need to enter it manually.
Code:
  Bandplan #0:   Base=136.005     Offset=-4.02   Spacing=7.5   BW=12.5
  Bandplan #1:   Base=136.005     Offset=-4.02   Spacing=7.5   BW=12.5  Slots=2
  Bandplan #2:   Base=136.005     Offset=-4.05   Spacing=7.5   BW=12.5
  Bandplan #3:   Base=136.005     Offset=-4.05   Spacing=7.5   BW=12.5  Slots=2
  Bandplan #4:   Base=136.005     Offset=-2.235  Spacing=7.5   BW=12.5
  Bandplan #5:   Base=136.005     Offset=-2.235  Spacing=7.5   BW=12.5  Slots=2
  Bandplan #6:   Base=136.005     Offset=-2.145  Spacing=7.5   BW=12.5
  Bandplan #7:   Base=136.005     Offset=-2.145  Spacing=7.5   BW=12.5  Slots=2
  Bandplan #12:  Base=769.000    Offset=+30     Spacing=6.25  BW=12.5
  Bandplan #13:  Base=769.000    Offset=+30     Spacing=6.25  BW=12.5  Slots=2
  Bandplan #14:  Base=851.0625     Offset=-45     Spacing=6.25  BW=12.5
  Bandplan #15:  Base=851.0625    Offset=-45     Spacing=6.25  BW=12.5  Slots=2
If I was to enter these manualy, how do I enter the offset?
my 536 does not have a place for the offset
mciupa
Canadian DB Admin
Moderator
I'm here a lot
If I was to enter these manually, how do I enter the offset?
Skip that part. Looking at my 536 and 325, they both have band plans like the picture in post #8 and I listen to MTO on both scanners.
You may be on to something. There was problems with P25 Band Plans in the BCD 996P2 which was fixed with firmware v1.07.07 back in 2017. What version are you using now?
Find that by going to Settings and scroll until you see Scanner Info. From what I read online, they are currently up to v.1.11.03 from 2024.
