Need help with XPR8400 code plug
WSFF627
I'm looking for a blank CP for a XPR8400 model AAM27TRR9JA7BN running firmware version R02.20.12 that will work on CPS 2.0 I have the "old" CPS 16 as well, but it appears the current CP, version 12.02.00 is missing some settings. CPS 2.0 will not read the current CP. Is anyone able to assist? I found a previous thread that someone had one, but the thread is closed and I can not locate the commenters email to reach out.
Thanks in advance!
RadioGuy7268
PA
In CPS 16 - are you in "expert" view? I'm not aware of any hidden functions that are going to appear on an XPR8400 just by using CPS2.
What are you trying to achieve? You could just roll up your firmware to a newer release using CPS16. Most folks with XPR8400's never upgraded to modern CPS2 firmware. There wasn't a need to.
K9KLC
Southwest, IL
I've forgotten to switch to expert view a couple of times when I re-installed the CPS and ya, stuff is definitely missing.
WSFF627
I completely forgot to switch to expert view. But I'd still like to find a blank CP that works for CPS 2.0
