need help
Forts
Ontario, Canada
Ok... I will assume you have Freescan loaded and running, and your scanner is ON and plugged into your cable/PC...
Click on Scanner...
Now go to Download Programming...
Click on the 'COM1 115200' button to go into the port selection...
And click on Start Auto to find your scanner....
Now hopefully at this point it will come back and say it's found your scanner.... Once we get past this point it's all gravy...
enjoy425
Hamilton,Ontario
ok it has found the scanner but it is in com 4 not 1 does this matter if not then the pc has found the scanner and am ready to go
Forts
Ontario, Canada
Ok.... It found your radio, that's great. Now in Freescan go to File -> Open then select the file I sent you. It should load and open up. Click on Scanner again from the menu options up to, then this time hit Upload Programming. A new window will pop up similar to what you saw last time. Make sure COM4 shows as the selected port, and also click on the little button beside 'Erase All Systems & Settings'. This will wipe out anything that is in your radio now (giving you a clean slate to work with). Now click the Start Upload button. If all goes well the file will transfer, the scanner will reboot and you should be off and running!
enjoy425
Hamilton,Ontario
thank you all I'm up and running
Forts I have it up and running and would like to thank you so much for your time and troubles of helping me out it was appreciated ,it's people like you that take the time to help newbies out and it was you that was the one that made me sign up as a member ,and I like to thank torontokris for his reply and special thanks to eriley to ,it is people like you's that are friendly and willing to go that extra mile to help newbies out.and I'm sure there are others that are will to help to and if everyone works together this site will go on forever,I would like to specially applaud the ones I mentioned above
thank you all so much
hope I can help someone out some day
Gary
Forts
Ontario, Canada
Great! Glad you got it working! Now as you look thru the manual and play with the radio hopefully things will make a little more sense.
