Need help!!
USAF_Pilot54
I have skimmed through the website, but haven’t found good help. (Don’t judge) I’m new to radio programming and I have a Motorola XTS 1500, the programming cable, and the software for it, but CPS keeps telling me that the radio isn’t found… I bought the radio from a person who I assume was getting rid of them for their police department. And I’m trying to remove all the channels frequencies from it and replace them with my local fire departments frequency. I’m glad to further discuss more if anyone can help.
Giddyuptd
Here and there
Probably a driver issue. Make sure the com port is properly selected in the cps. It's one of those 2.
K2NEC
5F6
And what's the programming cable look like? The XTS1500 and XTS3000 cable are the same physically but have a different pinout and not interchangeable.
USAF_Pilot54
n3obl
ØAES-1056
PA
Well there your first problem!! Notice the word "mobile". you need portable cps.
USAF_Pilot54
So I have the correct program now, and I think I've deactivated the transmitting buttons, would someone be able to show or teach me step by step on how to turn the radio into receiving ONLY!!! And how to put in the frequency I want?
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Considering the complexity of the software that you'll be using, what you're asking would be difficult, if not almost impossible, in a text-only environment like this forum. Your best bet would be to study the multitude of youtube videos on programming Motorola radios. Be sure to learn the "language" of what all of those thousands of settings relate to, since only one small error can prevent your radio from functioning properly - or at all. Are you aware of which band your radio operates on versus which frequency you wish to monitor?
MTS2000des
5B2_BEE00 Czar
And if it's trunking...well...there are plenty of threads on why this is a bad idea, especially for a novice.
The CPS help files do contain videos of how to get around CPS and do things like drag and drop, pick lists, etc.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
As a system admin trainer and system maintainer................if you slip up, there is a good chance you will be committing a crime AND/OR causing issues with an active life safety system.
TT
USAF_Pilot54
TT
What’s a good scanner to buy and easy to program then?
N4KVE
PALM BEACH, FLORIDA
Good scanner to buy, & easy to program can’t be used in the same sentence. That would be called a conundrum. Although about 12 years ago I did see a scanner where you’d simply enter your zip code, & the radio would show the systems available in that area. Choose a system, & it’d show all the TG’s available. Then just choose the TG. But I don’t remember if it was a digital scanner, or just analog.
