New DMR
scotttissue988
Massachusetts
I’ve done that. Keeps getting held up on a few particular frequencies with nothing but silence and then later I get voice on the very same freq, wasn’t paying attention to which slot. CAP+ displays on the screen as well when this happens. Friday afternoon as I was playing with it I even picked up a TGID on one freq.
W1KNE
Royal pain in the keister
New England
That is because it is a CAP+ system or conventional linked. Either way, the only way to avoid this, is to program it as a CAP+ trunk with each site.
When you do so, if you don't have any TGs assigned, then just add a dummy one. (i.e. 1 and label it, Dummy 1 or etc).
Then set the overall system to ID search.
Each set listed above will be its own site, FYI. Don't worry about LCNs at the moment.
EricCottrell
Boston, Ma
I had errands to do in Nashua, so I had supper at Zesty's in Chelmsford. I took along my Radio laptop and did a spectrum recording of the 460 to 465 MHz band while driving through Chelmsford. I like doing spectrum recordings because I can play it back and decode multiple frequencies (one at a time) using DSDPlus. I was able to catch some of the sites.
System is Motorola Linked Capacity Plus.
It looks like the lower repeater frequency is Channel 1/2 and the higher repeater frequency is Channel 3/4. So far all the sites are DCC 7.
Site 1 Chelmsford Public Schools Administration Offices 230 North Rd
461.5875 Channel 1/2
Site 2 Chelmsford High School 200 Richardson Rd
463.4375 Channel 1/2
Site 3 McCarthy Middle School 250 North Road
461.6375 Channel 1/2
462.0375 Channel 3/4
Site 4 Parker Middle School 75 Graniteville Rd
461.6875 Channel 1/2
Site 7 Harrington Elementary School 120 Richardson Road
461.6625 Channel 1/2
scotttissue988
Massachusetts
Thank you!!!! Zestys was a great choice. I’m running a trunking discovery today on some of these sites, 4 hits so far!
W1KNE
New England
FYI This has all been put into the DB.
scotttissue988
Massachusetts
Awesome, thanks! Were you able to figure out who is who on the TGID based on convo? There are a bunch of “i” TGIDs too, plugged it in as i0, will keep listening in discovery mode on my days off to figure out more TGIDs. I’ve picked up 10,110, 120, 160 and 180. Unit IDs also correlate with the TGIDs. 9000s are on TGID 180 which I believe to be Chelmsford Community Education also known as CHIPS.
EricCottrell
Boston, Ma
I had to go up to New Hampshire today, so I did an experiment using my SDS200 and SDRPlay RSPDx for spectrum recording.
Looking at the sites, it was possible the numbering went Admin, High, Middle, and Elementary with each school in alphabetical order within the category. It was also possible each site had the LCN in frequency order of the repeaters. I created a favorites list for my SDS200 based on these assumptions. I also drove by the sites doing spectrum recording and picked up some voice traffic on the SDS200.
It turns out site numbering is as I figured. The LCN is in frequency order of the repeaters except it is flipped for site 9. I also discovered site 1 appears to be using an unlicensed frequency.
I suspect each school has a simple setup with at least a main talkgroup.
100 Admin
110 High School (confirmed by another SNE user)
120 McCarthy (confirmed)
130 Parker
140 Byam (confirmed)
150 Center
160 Harrington (confirmed)
170 South Row
180 Community Ed
On Uniden scanners, Channels 1/2 = LCN 1 and Channels 3/4 = LCN 2.
461.5875 Channels 1/2 (confirmed)
463.3375 ???
464.9375 Channels 3/4 (confirmed)
463.4375 Channels 1/2 (confirmed)
464.9625 Channels 3/4 (confirmed)
461.6375 Channels 1/2 (confirmed)
462.0375 Channels 3/4 (confirmed)
TG 120 used
461.6875 Channels 1/2 (confirmed)
463.7875 Channels 3/4
Site 5 Byam Elementary School 25 Maple Rd
462.4000 Channels 1/2 (confirmed)
464.4125 Channels 3/4 (confirmed)
TG 140 (used)
Site 6 Center Elementary School 84 Billerica Rd
462.2500 Channels 1/2
464.1125 Channels 3/4 (confirmed)
461.6625 Channels 1/2 (confirmed)
463.4875 Channels 3/4 (confirmed)
TG 160 (used)
Site 8 South Row School 250 Boston Rd
463.5375 Channels 1/2 (confirmed)
464.4375 Channels 3/4
TG 170 (used)
Site 9 Chelmsford Community Education 170 Dalton Rd
463.6375 Channels 1/2 (confirmed)
461.3000 Channels 3/4 (confirmed)
This was just a quick survey. I may dig into the spectrum recordings more to see if I spot any activity on 463.3375 (site 1).
EricCottrell
Boston, Ma
I dug into the spectrum recordings some more. I found that 464.9375 was an image and Channel 3/4 is really 463.3375 MHz. I also confirmed a few more frequencies. I thought the Radio IDs (RID) were based on the site (50xx = site 5), but then the radios on site 3 are 40xx.
463.3375 Channel 3/4 (confirmed)
TG 120 (used) RID 4004 4015 4020 4021 4022 4023 4031 4039
463.7875 Channel 3/4 (confirmed)
TG 140 (used) RID 5002 5003 5013 Private call heard
TG 160 (used) RID 7006
TG 170 (used) RID 8011 8013 8028
TG 180 (used) RID 9024
