New England Area Milcom
thom
New England
Right now 303.0 (Winchester). No callsign but Boston Center mentioned. This is not related to coronet mentioned.
dispatcher812
Connecticut
The first thing you need is the scanner. You need a scanner that will cover the UHF milair band. Your new uniden will do that for you. You have that covered.
Second thing are the freqs and according to you you have them already. Its important to have all the aerial refueling or "AR" freqs programed as well as the ZBW "Boston Center" freqs. This is where military aircraft make their first contacts with ATC.
Third thing is the antenna. You really should have a good outdoor antenna up as high as you can possibly get it. Now there are a few antennas on the market that are made specifically for the milair band but a discone will work just fine. I would also use a preamp between your radio and antenna to help pick out weak signals. So you have the first two covered how about the antenna? What are you using for an antenna Kevin?
Rob
Rob,
I thought I had what frequencies I needed but after looking at this: Category:Milcom - The RadioReference Wiki I see I am not even close to having what I should. Some of the frequencies posted in this thread I do not have. How can you get all those frequencies from the wiki programmed with out doing it all by hand? I can not find in Sentinel where to get any more besides the common. For instance I do not see 126.350 any where in the frequencies I found.
Kevin
pro106import
Milford, Ct. perched high above Long Island Sound
Rob,
Kevin
I use Freescan which has a feature called "Ez-Grab". You copy the freqs into your clipboard (highlight them and right click, and click "copy). Then got to Ez-Grab and click copy from clipboard. Works very well.
Bob
KILLER (MA 104th fighter wing F15's) flight of 4 working GIANT KILLER on 338.100 AM.
KILLER A2A 259.900
KILLER and RAGE working FOOTROPE on 267.800 tracking TOI's
Time 13:49UTC
Thom you must hear them loud and clear when they make their transit through CT back to Barnes.
thom
New England
Sometimes I see them fly over my house on their way south to W 105 and back. They make a racket.
RAGE-1 (104th F15 fighter) is talking with Boston Center on 307.900. I guess their heading to W105 for their morning session. :)
RAGE flight now with Boston Center on 292.150. Also on 264.850 A2A.Time 1335UTC.
Looks like PACK-11 (KC135 tanker) is set to meet up with RAGE flight for some refueling OPS today. Awesome!
PACK-11 (KC-135R 133rd ARS, NH ANG Pease ANGB NH) is entering W105. Call made to GIANT KILLER on 135.225 AM. Time 1401UTC
PACK-11 is working tanker boom ops with the RAGE and KILLER flight on AR PRIMARY 289.0. Time 1427
PACK-11 (KC135 tanker) is in contact with EAGLE-11 about refueling times. Also mention of a SINNER or SKINNER flight. 323.80 AM Time1940UTC
STEEL-62 (KC-135R tanker 147th Pittsburgh PA) is working FORCE-20 in AR777 315.900. Time 1420UTC
