New Feed Oconee
supernix
Hello,
I noticed the only feed for Oconee county was down for more than a few days, so I decided to get setup with a feed for people to listen to.
I have had my Pro96 scanner since 12/20/2005 as I recall, but I never use it all that much.
Well until recently that is.
The actual intent for this post is that I was looking for feedback on how it sounds and such.
I followed the instructions on setup to get the feed going still not sure what all that meant.
I don't know exactly how to link it to show the feed, but the URL I get in the live audio section is:
Oconee County Public Safety Live Scanner Audio Feed
Hardrock40
Easley , SC
Sounds ok, some strange background noise on a few.
I would trim the amount of agency's you have going there. Might be hard to keep up with one when something gets interesting.
I run 2 scanners,1 local for feed the other I just listen to with bunch of frequency's, if something good happens on the non feed scanner I just swap the speaker plug over to it and lock it on that channel until its over. Then swap back to my primary feed.
Its hard to keep up with so many unrelated conversations. But some people might like that better.
Good luck and have fun.
supernix
I have since purchased a 12 foot coaxial cable to extend the rubber ducky antenna outside of my home to see if that might improve reception if that might have been the problem and I also changed the audio patch cable from a stereo cable to a mono cable to see if that improved the audio.
So hopefully all that has made a better difference in the feed.
I had been thinking about how hard it is to follow the conversations on the scanner feed app on my smart phone since you don't have that scanner screen to see who is saying what. Not quite sure what to trim out. The listing of all the frequencies are on the feed description page. It is a dump of the actual bank 4 from the scanner using Win96.
canichols
Oconee, SC
As a Oconee resident and scanner listener these are the frequencies you may want to cut as I have never heard anything on them or they are fire grounds channels. The database is up to date on all Oconee Public Safety frequencies. There is one talkgroup on the Pal800 for County dispatch to talk to the OMC EMS dispatch it is 52576.
Oconee Co SO Ch3 460.32500 DC 315
Oconee Co SO Dispatch 460.17500 CT 186.2
Seneca PD Dispatch 460.27500 CT 186.2
Walhalla PD Dispatch 460.30000 CT 186.2
Westminster PD Dispatch 460.47500 CT 186.2 Dsipatch by county
Oconee Co S 460.25000 CT 186.2 cut if ther is any traffic it is mototurbo
Keowee Key F 154.26500 CT 103.5 cut never hear anything
Oconee Co Fire Dispatch 154.13000 CT 103.5
Oconee Co F 155.01000 FM 0.0 cut fire grounds
Oconee Co F 155.77500 FM 0.0 cut fire grounds
Oconee Co F 154.29500 FM 0.0 cut fire grounds
Oconee Co F 154.28000 FM 0.0 cut fire grounds
Oconee Co F 154.26500 FM 0.0 cut fire grounds
Oconee Co F 150.80500 FM 0.0 cut repeter input i belive
Seneca FD 155.82000 CT 186.2 cut fire grounds
Seneca FD 154.31000 CT 186.2 cut old not used any more
Oconee Co EMS Dispatch 152.40500 CT 192.8
Oconee Co Rescue Dsipatch 151.13000 CT 210.7
Oconee Co E 155.28000 CT 192.8 cut never hear anything
Oconee Co OMC Ambulance to Hospital 155.34000 FM 0.0
Seneca City Fire Dispatch 151.04000 FM 0.0
Walhalla FD 156.24000 FM 0.0 cut never hear anything
Oconee Co S 158.88000 FM 0.0 cut DPW
Westminster 153.45500 FM 0.0 cut DPW
Fire Departm 154.25000 CT 85.4 cut fire grounds
Sheriff s De 158.85000 CT 127.3 cut old not used in meny years
Fire Departm 154.28000 FM 0.0 cut fire grounds
Police Depar 154.75500 FM 0.0 cut this id toccoa PD dispatch
supernix
As I stated I pulled these frequencies from the RR database.
