- Joined
- Feb 25, 2025
- Messages
- 5
As title says, I am new to the Unication G5 and total lost on programing it. All YT videos are 7+ years old and the PPS software has advanced a lot since then. Any help would be amazing!
I got it programmed but no traffic is coming acrossAs premium subscriber to this site you can just download the system and talkgroups you wish to monitor with the G5 into the PPS
You still need to decide and configure which talkgroups you what or each knob position.
What are you trying to receive? What did you"Program" in it??As title says, I am new to the Unication G5 and total lost on programing it. All YT videos are 7+ years old and the PPS software has advanced a lot since then. Any help would be amazing!
That is like saying I put gas in the car but it is not running. You really need to tell us more about the system you programmed, how you programmed it, your profiles, and settings so we can help you.I got it programmed but no traffic is coming across
Interesting, where did this come from? What did it cover? What site did it connect to?So I found a code plug for my area
What sheriff's department? How did you add it? What screen were you on in the CPS when you added it?I added the sheriffs dept and programmed the scanner
Does it receive the fire stuff on the PPS you loaded into the pager?I am in Northwest Ohio Regional Public Safety System) but it didn't have the sheriffs dept just a bunch of fire channels.
So I found a code plug for my area ( I am in Northwest Ohio Regional Public Safety System) but it didn't have the sheriffs dept just a bunch of fire channels. I added the sheriffs dept and programmed the scanner but when I am on the sheriff channel I added there is a steady red light
Thank you for telling us the cause, so others with this problem can see what the issue may be.I got it figured out my so is encrypted @&(;(?)!;,?
