New here and have a question...
fletchman1957
SW Ohio
I recently installed a new Uniden Pro520XL and new Little Wil antenna on a Town & Country Van. I have SWR readings of CH1-1.6:1 CH20-1.0:1 Ch401.7:1
I did a radio check on CH19 and the response was that I was sounding good and throwing a good signal right about 3 miles away. But, here's what I notice inside the van, when I key up on any channel from 13-40 my TX lights all light up indicating a full TX, at least that's what I think it means. But when I transmit on channel 1 my meter only shows 1 bar lighting up. At channel 12 it lights up 3 bars until I get to channel 13 then it's full on. Should I be concerned?
merlin
DN32su
Your SWR is fine, so you need to look at how you are getting power and ground to the radio.
Many newer vehicles, DONT go to the battery. In your owners manual, find an accessory power point for positive.
Find a metal frame ground, and ground the radio chasis. You can get the negative power at that same point.
Never rely on internal power/swr indicators.
Mag mounts are good for metal rooftops, but if you mount to the hood or trunk lid, use a heavy ground braid between the frame ground and hood/trunk.
slowmover
Fort Worth
Manual doesn't comment on that senario.
Yes, it does.
RF output power is what you were citing.
Clue?
Test:
As above, try grounding radio chassis at same point in vehicle as 12V Neg.
(Test that point with multimeter).
Power output vs SWR?
Re-check.
slowmover
Fort Worth
Plus that todays vehicles aren’t welded, but adhesive-bonded. Continuity to 12V ground is a good test from any chosen antenna location. (It’s not a guarantee, but it’s a start).
Minivans tend to be good with CB.
fletchman1957
SW Ohio
I am curious, does your external SWR meter have a power meter as well? Some do and some don't I thought I would ask. If it does can you double check it with the external power meter to see if you see the same behavior?
Yes it has power meter too....AVG & PEP. It shows 4 watts dead key and swings to 8-10 when talking.
fletchman1957
SW Ohio
All, I have the positive wire from the cb connected to the positive terminal on the battery. The negative wire from cb is connected to negative terminal on battery. But, my cb is mounted to plastic inside the van. Should I run a ground wire from the cb chassis to a ground also?
KANE4109
Deer Park, TX
Here is the real point....
Using the external power meter.... does the power it shows going out stay up all the way across the band... or... at least better than what the INTERNAL meter shows?
In most cases... it is the "external meter" that I would trust more. If it says your power out is up good all the way across the band then my thinking is that what you are seeing is a "shortcoming" in the internal meter.
KANE4109
Deer Park, TX
Please consider (if you don't have one) finding some kind of fuse block, mounting it as close as you can get it to the battery, and run this power cord through it. Any point where that wire comes near metal could cut through the insulation and form a semi-welded short and the outcome won't be good.
