http://www.icom.co.jp/world/download/receiver.html
From the site:
IC-R1500 / IC-PCR1500 / IC-R2500 / IC-PCR2500 Control software
Ver.2.10 ZIP (4.81MB) 2007/06/11 updated
Control software for Windows® 98SE / ME / 2000 / XP and Windows Vista™
* Windows® 95, 98 and NT are not supported.
Major improved function,-
* Windows Vista™ supported
* P25 frequency coverage extension
* AFC function
IC-R1500 / IC-PCR1500 / IC-R2500 / IC-PCR2500 Firmware data
Ver.2.10 ZIP (743KB) 2007/06/11 updated
* AFC function
[Note]
* Please read "Software & Firmwareupdate information" (3.45MB) thoroughly and make sure what is required for the firmware update.
* When your receiver is already connected to the PC and it work normally, the USB driver is not necessary to update. If you would like to update the USB driver with new one, you have to delete the previous USB driver in your PC then you should install the new USB driver.
* Never turn off the receiver power while the updating is being performed.
* Save the setting data and memory data of your receiver before performing the software and firmware update.
* Control software (Ver. 2.10) and firmware software (Ver. 2.10) must be updated at the same time when the receiver software is updated.
P25 coverage extended?
Does this eliminate the need to modify the receiver to scan above 700Mhz?
From the site:
* AFC function
* AFC function
[Note]
