New Malahit DSP2 multi band
bearcatrp
Land of 10,000 taxes
Ratboy, have you tried on the roof of your apartment? Could help identifying the RFI. If you’re fairly clear on the roof, then possibly someone in the complex is the issue. Walk the halls with the radio, see where it’s the strongest.
rocky28965
Otago, NZ
I'm happy with mine and there are plenty of reviews on them.
But if you wait, a newer better one will come out for sure.
bearcatrp
Have seen the DSP3. I like the design of the DSP2 better. How is the waterfall display? Is it nice and smooth when rotating through the frequencies? Or choppy?
rocky28965
Otago, NZ
I may be wrong, but I was under the impression the DSP3 was an earlier model.
It's certainly cheaper.
The waterfall on mine is quite smooth, but that can be adjusted in the settings.
I have a Icom IC-R8600 and on the same antenna, the performance of the DSP2 is comparable.
I think the filtering is actually better.
If you do buy one, get some SMA male to SMA female adaptors and leave them on the radio.
I you swap antennas as much as I have you will need them to prevent waring out the ones on the radio.
ratboy
Toledo,Ohio
Hi ratboy, I guess its pretty cool in Ohio atm.
We're mid-summer here in NZ.
You are correct, when I use the memories, it saves the step setting.
I've already filled up all 50 of them.
Have you tried a loop antenna for your location?
Oh yeah, it doesn't matter much what kind of antenna I put on it, it just is horrible. I had an old loop antenna, don't remember what it was called, and it worked pretty great when I lived in my house. In '17, I moved to an apartment, and WOW, the RFI is amazingly bad. I bought another couple of them and they are of no help. I bought one of those RFI eliminator things and it was almost totally useless.
I work at a place that has a NOC in it, and it's almost as bad as my apartment is. The hash is worse at VHF Hi and up, but slightly less on HF. At either location, FM Broadcast is what you can get decently, along with VHF Air, rail, etc.
ratboy
Toledo,Ohio
It's everywhere, some places it's stronger, but it's at least a 20 over S9 and in some areas, it's like 50 over. Sounds like the worst flourescent light buzz times 10. The light above my sink not only throws terrible RFI, it buzzes audibly with the same buzz, so I never use it. Doesn't matter anyway, the other RFI sources are wiping everything out anyway.
ratboy
Toledo,Ohio
The DSP3 is the earlier model. I don't really understand the whole model numbering thing they are doing with these radios. The DSP3 isn't bad, actually, but the DSP2 is a lot better. The previous ones are really pretty sad in one way or another.
dxace1
Potomac, MD
NO -- the DSP-3 is the name of LATEST Russian receiver. The China clone being sold on Ali and elsewhere is the DSP-2 which is the
earlier version of the Russian Malachite by Malahiteam. Let's not get things confused. The earlier DSP-2 uses firmware 2.40 which is
or was as of the time I write this, the latest fimware for the EARLIER receiver. I have not seen the DSP-3 being sold on the China market.
bearcatrp
I looked at Malachite web site. Shows pre order for the DSP3. With embargos against russia, doubt they will build it until most countries lift the embargo. Was just asking folks with the DSP2 how things were going so far.
ratboy
Toledo,Ohio
Mine is doing fine. Zero issues of any real kind. The noise from the display is a little annoying, but that only really happens on the whip. An external antenna, like a mag mount CB antenna, works pretty great. I went train watching and tuned around and heard all kinds of N. American and European CB skip very well. I put a friend's 20M mag mount on the roof and it was blasting in, 15Mhz broadcasters were VG too. The battery life is good, and the audio is about as good as something that size could be. If I could change anything about the size or whatever, it would be to make the format horizontal, and make the display bigger.
G7RUX
Of course there is the original Russian-made DSP2 as well (I have one of these) and it's a decent bit of kit. For me it only has one issue but this is one that wouldn't affect US users since airband in the USA does not use 8.33 kHz spacing as far as I am aware.
MrThompson
Kalifornia
Radioddity currently has a the DSP2 on sale at AliExpress prices during their Anniversary Sale. It's shipped from Las Vegas and you get their incredibly responsive customer support. They ship fast, two day delivery to central Kalifornia.
I'll add that I'm an old HF DX snob. My references are a two R390As paried in diversity or with a Sherwood SE-3, Collins HF-2050, a John Thorpe configured AR7030 Plus with Kiwa mods, AR5000 with a DSP-599ZX, Airspy HF+ Discovery along with a Lowe HF-150 with Kiwa mods and a couple of Belkas for patio use. I've only had the DSP2 for one hectic week with limited use due to time constraints. If you're familiar with SDR's and willing to tweak the settings it's a superb receiver.
Ishmole
Walden, NY
I have the DSP-2 and love it. It serves me well for the things I need to monitor. What I really like is the Hi-Z and 50 ohm separate connectors. I can here many SW broadcast and hams using the supplied whip and setting it at Hi-Z.
Tuning CW and FT8 with the built in decoder is excellent.
One thing that bothers me is that there is no detailed information on doing CW and FT8. I am trying to use the RTTY decoder with no luck.
I wish there was an "Easy to read" manual for this rig like the ones they wrote for the SDS 200 and the like that describe the best way to use all the features the radio has.
Has anyone found detailed user manual for this radio?
Mike
bearcatrp
Keep considering getting this radio but some of the reviews has me backing out. I almost bought one until I found the LAN IQ. I do like the case on the DSP-2 vs the LAN IQ. So far the LAN IQ is doing the job for me. But always on the hunt for a better HF receiver.
Ishmole
Walden, NY
I have no complaints on the performance of this radio. It works well on AM broadcast and shortwave frequencies using the HI-Z input and the supplied antenna. I had the earlier smaller version and it did not, unless it was connected to my outside HF antenna.
The FM broadcast screen is nice as one of the displays shows the frequencies of the RDS carrier, L-R and the Pilot tone at 19Khz.
Just a fun receiver to play around with as it has all the neat features.
