Avery County joins the switch to NXDN in the state prison at Spruce Pine.
Here's the list of all licenses I've seen so far...
Do you guys have a way of seeing when new licenses get added or do you manually search every day?
I live in CT so the NC won't help me - Do you mind sharing the website that you use so I can follow it for CT?I post a list of new NC grants each week and also email out the list.
North Carolina New License Grants
Another week, another post, hope you all managed to stay safe from the looting and rioting out there, and hopefully heard some interesting comms on Viper or your local systems. With that said, on to this weeks post. Below is this weeks (05/30 to 06/06/2020) NC license grants. If you would like...forums.radioreference.com
I've searched CT on the fcc site and then sorted by latest date. Maybe you have an easier way.I pull off the FCC website, but I will send you another link later this weekend when it comes out for the whole US
Central Prison in Raleigh, which also holds a license for an NXDN system, is being heard a lot more, but it appears they are only using a NXDN single channel (NO CC) rather than a system. All traffic without TGs is on 453.050
The VIPER infrastructure scheme was originally designed as a 95% mobile and portable radio outside coverage system, not as a 95% portable radio coverage system. Therefore VIPER has more than a plethora of locations inside buildings all over NC with absolutely no viper coverage.
If an entity chooses to become a user of VIPER and requires 95% in-building VIPER coverage, then that entity will require the money to increase the infrastructure and connectivity in that coverage area in order to meet the 95% portable coverage goal.
Pick any metro geographical area in NC with a local entity trunked 700/800 system and compare the number of local entity trunk sites to the number of VIPER sites serving the same area. Unless there is appropriate connectivity infrastructure installed inside the building, a VIPER user entering the first 50 feet of the lower floors of the local courthouse or hospital or jail etc., is then likely toting a multi $K dead weight on his Sam Brown belt.
I worked in the public safety radio business and was a fire-rescue volunteer for nearly 40 years, and I can tell you that no matter what frequency/power/modulation scheme a radio system may possess, there is no such thing as 100% coverage inside anything built of masonry, steel, and dense concrete. Add in terrain and ground clutter and you have a further reduction in communication. I can name a plethora of locations where the local system has coverage due to the numerical superiority of numerous sites and VIPER has absolutely none. Dead locations inside structures are a fact of life in any system. Nothing but smart design and additional connectivity infrastructure and site modifications hold the possibility of resolving the problems.
Whatever the reason may be for going to NXDN, the efficacy of the necessary interops scheme with VIPER will be the telling factor as to whether the move is good, bad, or stoopid. I have an idea the choice of NXDN has a lot to do with a lower cost route to channel security and connectivity of comm infrastructure in a narrower and more specific purpose application.
Former CO here. Correctional officers also do medical transports for inmates to receive specialized care outside the walls, and occasionally transport to court hearings in other areas. Our radios were on the county net for that reason
