new old guy
jce2492j
Hello I,m getting back in something that i use to enjoy as a kid long story short. I bought a bcd536hp and wondering if i can use Windows 7 for sentinal downloads? Thanks.
Ubbe
Stockholm, Sweden
No problem. I have been using Win7 without any issues for years and have recently made a dual boot to use Win10 and that are also working without any problems with all radio related programs I have tested.
/Ubbe
KK4JUG
GA
It'll work.
The only reason I quit using Windows 7 was the fact that Windows quit supporting it thus inviting unwelcome visitors.
jce2492j
Thanks for the replies. Would this update improve this bcd536hp? I,m in Liberty county MT. Im not recieving much with just a ZIP. code
KK4JUG
GA
It might help but your biggest problem may be the fact that the population is so sparse that not a whole lot is going on.
Ubbe
Stockholm, Sweden
The database that comes with the BCD536 are probably from 2016. You will have to download the latest database from Uniden to be updated and then do the zip code selection. But if you live where there are few people using scanners, then it might be several systems that are not in the database as no one have reported anything to RR. The database are depending on that people with scanners are reporting their findings to RadioReference that then Uniden uses to create their own database.
If there's not much to monitor even after you update the database then you'll have to do frequency searches to find what's out there. You can program 10 search ranges in the scanner and I suggest to set the delay for each one to -10 sec, negative 10 sec, and start the recorder. It will then stop on active frequencies and save the audio and after 10 sec it will continue to scan. If you notice that it stops on the same frequency several times without any conversations are heard you can do Avoid to that frequency.
Let it do searches for a full week whenever you are not actively listening. When done you can install the Universal Audio Player by deim here in the RR forum and copy the audio folders from the scanners SD card, there's 100 recordings in each folder, and put in the same directory as the audio player and have it show the info from the channel and also listen to the audio. Then collect all info and program the scanner with any new info you have discovered.
/Ubbe
jce2492j
Thanks for the help i will be asking alot of questions this is all new tech. to me.
