New Remtronix VHF/UHF 2 meter and 440 MHz Antennas!
iMONITOR
Silent Key
S.E. Michigan
Did anyone else notice the "Diamond" in the link? How about the similarity to the RH77CA?
That's really weird! If I click on it it takes me to:
I think Universal Radio just used an old website link from a previous spot for a Diamond antenna and didn't do a good edit job. I received the Remtronix today and there is zero similarity between the Diamond RH77CA and the Remtronics REM-VU100B. The loading coil at the base is different design just looking at the outside. The antenna element on the Diamond has a very slight step in the diameter wherer the Remtronics is the same it's full length. The Remtronics is installed and I've been monitoring commercial aircraft since about 5PM and I can't tell a difference. Previously I was using the stock Uniden telescoping antenna. Both were on a mag-mount on a file cabinet in my office. I'll play around more this evening and tomorrow. I'm monitoring VHF aircraft.
INDY72
Indianapolis, IN
Remtronix former GRE antenna gear is 99% scanner only gear. Someone added amateur radio wording on it for sales only. These are all awesome for recieve, and I would never trust an Remtronix or the original GRE/Radio Shack antenna to put on an HT and use to broadcast with. Seriously about the best lower priced scanner antenna on the market. But to actually use as a HT antenna, sorry but not me. JMHO, but there it is. RX all day, nope on the TX part.
iMONITOR
Silent Key
S.E. Michigan
Well I've had my new REMTRONIX VHF/UHF 2m/70cm antenna for a couple weeks now. So far it's about what I expected. If I had to guess it might be performing a little better on VHF than the Diamond RH77CA. It should be noted I'm using it for the VHF airband, not VHF amateur radio.
I originally had it on a big magmount on my 4-DR steel filing cabinet in my home office but there is a big window with metal mini blinds (closed) within three feet of it, along with a 2'X2' aluminum picture frame right behind it. So I moved it to the top of a hutch on one of my desks. I also have a PAR VHFBP Aero Band Pass filter that also provides protection from VHF pagers, NOAA, 2 meter amateur signals etc., as well as excellent attenuation of the FM broadcast band. For such a small package indoors I think it performs well. It could be my optimism but air traffic seems to have increased substantially but I have no technical/scientific way to prove it.
krokus
Southeastern Michigan
Have you thought about using a ground plane with it?
N4DJC
Upstate
I’d try one of the Smiley Super Stick II telescoping aircraft band antennas, 48” long (similar to the old AEA Hot Rod) but I’d think it might work better.
