New Sat dish for McMurdo Station
n0nhp
Grand Junction
A new satellite dish is going in at McMurdo Station Antarctica, There is "Live video" of the construction at The USAP Portal: Science and Support in Antarctica - McMurdo Station Webcams
Go to the RIES Construction tab and in the lower left corner you can get a time lapse of the last 24 hours.
The dome seen in the background before the zoom is the NASA telemetry site.
This will replace the Earth Station on Black Island that I baby sat for a couple of seasons in early 2000.
Bruce
prcguy
That looks like a General Dynamics 11.1m antenna which I'm very familiar with including all the RF and servo components. I suspect the entire back structure will be enclosed with the optional heaters for the reflector considering where its going. I wonder if its C or Ku or other?
n0nhp
Grand Junction
The one it is replacing is C band Intelsat if they are still using the same provider, I have lost track in the last 20 years ;-)
merlin
DN32su
Too cold for me, nice dish though. I gather it will have a dome when done.
n0nhp
Grand Junction
Oh yes, there will be a dome. It would have a tough time staying at it's 7 degree look angle with the wind conditions that occur fairly often. Snow is not too much of a problem, it doesn't snow much there, but what lands doesn't melt except for a couple of weeks in January, it just blows around.
prcguy
If its in a dome then it won't need the enclosed back and heaters. 7deg look angle is not good and would be a big problem on Ku. Not as bad on C-Band but anything below about 10 degree look angle will suffer scintillation and fading due to tropo ducting. Whatever satellite and transponder(s) they are using would probably get away with a much smaller antenna further north and I'm sure they upsized the antenna to ensure the link budget would be ok under any conditions.
JamesWest
thanks for posting this story. it is very interesting.
anybody know what that dish costs? i need to replace my patch antenna. 555.
PACNWDude
+1 on the thank you for sharing. I began my comms career in satcom, then went to Land Mobile Radio, but also spent some time as an engineer for Zetron, and a team came through the 40 hour dispatch course, they were going to upgrade the dispatch system at McMurdo. Would have been nice to have gone there with them, as "tech support". Lucky people. My only option now is to go as a tourist.
n0nhp
Grand Junction
Hmmmm, What year on the Zetron course? I took it for just that reason in probably 1999?
We put in some 4010s
We may have met :)
Bruce
PACNWDude
We may have met :)
Bruce
That is about the right time frame. Very possible and likely.
thebaldgeek
thebaldgeek
SoCal
Anyone know if this will be used for aircraft (ACARS/ADSC) use?
I track aircraft heading back and forth from the ice and would love to see better coverage down south.
n0nhp
Grand Junction
The installation it is replacing is the main Data / Voice path to CONUS via geostationary commercial satellite and last I heard all voice was VOIP. So I doubt except for data on the internet, it will carry any ACARS or ADS-C traffic
ka8ypy
Nice install, I started in Satcom, went to telco, then radio/lights/siren install, then welding, and now back to satcom.
k7ng
Electronics professional
CN73
I ran into some issues, once upon a time in a land far, far away, that using a larger dish at a very low look angle made the scintillation / refraction effects worse. The narrower beam gets messed up in entirety instead of only part of the wider beam from a smaller antenna. But I'm sure someone worked this all out for McMurdo's new install. Not like when Naval Systems Engineering put up a great big LPDA right next to the main office and it came down that winter. While I was on watch.
Viewing McMurdo from Ob Hill webcam brings back memories (not all good ones, either). The town has changed some, but I still recognize a lot of the buildings.
dlohmaii
Carthage
I'm going to have to tell my father about this, he was there for Operation Deep Freeze 83-85.
Thanks for sharing.
