New Texas interoperability channels
Oh, very nice! 151.1300/1375 is the input to Dallas Ch. 32 (PGB) Repeates on 157.3500 PL: 162.2
151.1450 I havn't seen before. 155.4450/4525 is Metro or Primary-B or Channel 29-Dallas (NDT) [North Dallas Tollway]
155.4750/4825 is DPS-20 (National Police Channel) Not sure of 155.7450/7525. and finally, 155.7600-DPS Executive Security
But I do believe all of these are Standard Operation Frequencies, I guess its just how the State Radio Service re-licenses them as to how they are designated.
garys
Central Texas
The VHF and UHF interoperability frequencies (nationwide) are as follows,
155.7525 V-TAC CALL
151.1375 V-TAC 1
154.4525 V-TAC 2
158.7375 V-TAC 3
159.4725 V-TAC 4
453.2125 U-TAC CALL
453.4625 U-TAC 1
453.7125 U-TAC 2
453.8625 U-TAC 3
The VHF are simplex, but I think that the UHF are set up for repeater or simplex use. As of 1/1/2005, the primary use of these frequencies will be for interagency coordination. All other uses will be on a secondary non interference basis.
These frequencies are open to all public safety agencies, not just police.
Gary
nd5y
Wichita Falls, TX
I think the reason why the state licensed so many additional interoperability
channels is to pretty much guarantee there will be several available that
are not already used in any particular area. I counted 60 VHF/UHF/800
channels.
Tom
garys
Central Texas
The state of Missouri has a fairly well advanced Interoperability plan for VHF and UHF. You can find it here, http://www.sema.state.mo.us/MO SIEC VHF-UHF April 2003.pdf
They are planning on using either carrier squelch or 156.7 as the standard PL. Call channels will be analog (from the looks of it) with CSQ. Other channels will be either analog or P-25 with a standardized NAC.
The UHF channels are set up for either repeater or direct operation. The direct channels will be on the repeater output frequencies.
Someone I spoke with who deals with this sort of stuff thinks that the Missouri plan may be widely followed through the rest of the country.
VHF channels are mobile only, except for temporary bases.
There's a fair amount of information on the web and it's easy to find.
Gary
nd5y
Wichita Falls, TX
Texas is also supposed to be using 154.68 PL 156.7 as a public safety common channel like Missouri did, except ours will be called CTAC.
Tom ND5Y
HabboX
Lubbock, TX
It appears to me that the State of Texas decided to license all the frequencies adjacent to the published interoperability frequencies that use 12.5 kHz spacing.
BTW MaxTracker: 155.445 wasn't on that list. 154.445 was. It is often used by fire departments for dispatching.
garys
Central Texas
Isn't 154.680 currently a primary mobile channel for DPS?
Gary
nd5y
Wichita Falls, TX
Gary
Yes. I haven't figured out the reason they did that.
Maybe they figure just using a different tone will prevent
interference since it probably won't be used very often.
Maybe it will only go into effect when they switch the whole
state over to digital and move Ch 1 up to 155.4675/154.6875 or maybe
they plan to use another freq. for Ch 1.
Tom ND5Y
garys
Central Texas
Well at least I'm no more confused than anyone else. <G> I'm going to work on the assumption that not much will change between now and early December when I'm going to be down there. Just in case I put in 154.680 with the 156.7 tone.
Gary
OKisOK
Midwest City, Oklahoma
Regarding the interference issues and these UHF/VHF interoperability frequencies, the use of those frequencies must be compliant with FCC limitations (80) (…this frequency is available primarily for public safety interoperability only communications…) and limitation (27) (narrow band emission only). An eligible entity must have a license to operate a base or control station on these channels. Public safety licensees who are eligible to hold a Part 90 license, or who are otherwise licensed under Part 90, can operate mobile units on these channels without an individual license. The Third MO&O states, "Prior to January 1, 2005, interoperability use will be permitted only on a secondary basis to existing users; that is, interoperability transmissions can be made only when the channel is clear and on a non-interference basis." Particularly related to use as base or control stations licensed on these channels, the FCC will license interoperability use on these channels, the FCC anticipates a condition on any such license making interoperability communications secondary to the existing licensees until January 1, 2005. Incumbent operations licensed and operating on these frequencies prior to December 7, 2000 in non-interoperability manners are consider to be co-primary until January 1, 2005 at which time they will become secondary to any interoperability operations.
oop's Thanks John I didn't see that it was 154.445.
My Guess nd5y on 154.6875 is with DPS implimenting Digital, the Line up of the Chanelization my change. making DPS 154.6875 or 154.6800 no longer the Primary Mobile input to 155.4675. Who knows!
MT
