296d is a very old scanner from 16 years ago! Shouldn't even have been in this discussion, unless you can find one on ebay and there is only one as I write.
EDIT: I missed the part of your looking at less expensive models.
You'll have to look on the resale market for the others.
The models in message 2 is an old list of older
discontinued models, short of the two Whistlers.
Message 2 is missing current and much more capable portables,
Uniden 325P2, 436HP, SDS100
Whistler TRX 1
Even though NC is shown as phase I, if you went with any I list above these are able to do Phase II. If NC went Phase II your looking at a new scanner if you went with WS1040.
The other models if you wanted agencies can also do mototrbo, NXDN as well. 1040 cant.
I see your county is not simulcast - multi tower same frequency so no real need for the expensive SDS100.
Current model portables that would work WS1040(No phase II support), 325P2, 436HP and TRX1
If it was me, 325P2 would be the one and least expensive phase II and future proof yourself with phase II and the mototrbo, nxdn support if you want as an addon.
Edit yes least expensive portable would be the WS1040.
