SDS150: New Uniden Scanner announcement at SEMA 2025
Trucker700
I just noticed your Avatar photo. I am guessing that is the signal strength for each of the GPS satellites the SDS150 is located on to.
James
Ubbe
Stockholm, Sweden
Any chance there could be an option for auto brightness for the screen?
It's on our wish list for features we want in a Uniden scanner. Mobile phones got a light sensor and adjusts the screen to adapt to the current environment light. If used in a vehicle the screen will change if you go into a darker tunnel or if you get bright sunlight and portable scanners are used in the exact same situations, so why not have a $0.10 light sensor and a couple of transistors to control the backlight.
There could be a setting in the menu how much the sensor should affect the backlight, 25% 50% 100% and if you push on the On/Off/Light button it should toggle between Full/Off/Auto. Uniden can do so many things to improve their scanners, if they only wanted to.
/Ubbe
rbluesky
Hi All as with everything that's Brand new and just developed you might want to wait a while and watch the forums about the issues of
the NEW sds150 wait at least 6 to 12 months. the price is now $949.99 a lot of money for a TOY, Buy FOOD clothes and gas instead !
After 10 months and if no BIG issues like the battery burning down your house or car then consider it Maybe. Don't forget a lot of agencies are going to
700 Mhz encrypred, Boston PD did !
LarryVavrek
Estero
Until encryption either goes away or a solution to decrypt comes around I'll save the $1000.
trp2525
is butel software being built out? for this radio and can we use it for all the other RADIOS? just a question.
Butel is currently listing their ARC 536 software for the SDS150 on their website. The same software is also used for the SDS100, SDS200, USDS100 and USDS200.
There is currently a Black Friday special going on which brings the price of ARC 536 Basic down to $31.96 (regular price $39.95) and ARC 536 Pro down to $55.96 (regular price $69.95). Use promo code BLACK at checkout to get your 20% discount.
palmerjrusa
Frederick
I have the Butel software but found myself using the Sentinel software the most.
dhmann1811
Regarding GPS, is it safe to assume (yes I know) the antenna must have good access to the sky to properly work? If I had the scanner sitting in my center console without being connected to an outside antenna, the GPS would not work. If someone could confirm or explain like I’m a 5 year old I’d appreciate it.
Trucker700
I think it depends on several factors. I have a Icom 5100a that has a GPS in the remote control head. I normally mount it in a cup holder mount instead of up high on the dash. And it still aquire a lock on several satellites very quickly. I would imagine that the GPS in the SDS150 would be just as sensitive.
James
Trucker700
It's possible I missed it, but I'm surprised no one has asked if they can send their SDS100 in and have the GPS added. :rolleyes:
I wondered about that. I think that there may be enough difference in the case design and the internal hardware that it might not be practical ( cost effective for Uniden or the customer).
James
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
The best guess is it will be an upgraded version that would work with the SDS100 SDS200 and SDS150 from what I have seen the beta testers posted pictures.
I forgot to add the updated version of Sentinel added the SDS150. You can use for the BCDx36, SDS100 & SDS200 as well. Just pick the proper Target Model for the profile/radio you are programming:
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Search and you'll find that this has already been answered.
