Hi I saw this thread and thought I should respond. The difference between 28MHz and 50Mhz is quite a jump from a propagational perspective. The experiment is to gain understanding of the difference in E-Layer propagation and determine of E Skip forecasting can be developed. The process will be to send WSPR and FT8 on 10, 8, 6, and 4m to determine if a 10m opening leads to an 8m opening ect. Then evaluating the openings perhaps a better understanding of E Layer ionization can be gained. Forecasting of these types of openings can help not only the ham community, but the broadcast industry as well, who is often plagued by co-channel out of market interference in the spring and summer. Our happy E Skip time is the broadcast engineers headache.So, what's the experiment?
Hams have 10 meters and 6 meters. Why spin this up on 40MHz? I mean, I get it, try a mode like WSPR on a quiet channel to see how it works, but I'd love to know the rationale for this...
This experiment can also allow the FCC to make decisions on how this spectrum is used in the future by gaining a better understanding of the propagational nature of the 40MHz band. That said this is not connected to or intended to be any sort of end run around an allocation, this is an experiment to see the different behavior of radio spectrum when the experiment is over it is over, but the understanding of F layer propagation may be explored if it appears to be relevant as the solar cycle increases.
Additionally no know two way transatlantic contact has taken place on 8m or 4m. At this time one of my 40MHz WSPR transmissions was received via multi hop E Skip in England. England does not have 40MHz allocated to hams so the receiving station could not transmit. The level was sufficient to have completed a FT8 and CW contact, but not likely to complete a SSB contact. I have conducted several unsuccessful attempts to contact Slovenia S5 who does have a 40MHz allocation. Ireland is a more likely candidate.
If anyone is interested in being a RX or TX station to be added to the experimental license please contact me I am good on QRZ NI4Y. RX equipment will be a home made fan dipole for 10, 8, 6, & 4m, a Raspberry Pi3 or better and an RTL SDR. Alternately a PC with a radio with SSB on 10, 8, 6, & 4m and the same fan dipole. Note 4m is going to be a bit tricky from a timing perspective and may be eliminated from the experiment. Further testing is needed to ensure no interference to licensed users occurs. Interestingly the main users of 72MHz pause transmissions for 30m each hour so this is very helpful. Equipment testing is on going.
If you're reading this far in the future check WL2XUP on QRZ.com for current details and experiment results.
73,
Lin NI4Y // WL2XUP
PS you said you would love to know LOL
