- Joined
- Oct 27, 2002
- Messages
- 2,287
- Reaction score
- 1,226
Thanks again for having a look. Other than viewing many of the readme files in the apps folder I haven't done any poking around in areas where I feel I might have thrown a wrench in the machinery. I can always blow up these virtual machines and start over, so that's not a big deal.
One thing that I wondered about as I read a few of the readme's was that in some cases it appeared I might have to open another terminal window and run "./audio.py -u 23456" if I wanted to hear audio. I "thought" that might be exclusive to multi-rx.py but not sure. In any event when I did so it told me that the port was already in use, so I guessed that the process was automatic. It appeared to me by looking in the stderr.2 file that it did use that port on startup. Since then though I've been through countless restarts so I wouldn't think that would be causing an issue. Interesting that your OP25 won't play back the audio.
It's interesting that it is exhibiting the same behavior on both machines which leads me to believe I am doing something incorrect at some point.
Again many thanks.
Edit: This is a shot in the dark but as I look at stderr.2 I am seeing as part of line 14, "do_output[0]". That to me says something is turned off?
Edit #2: Now that I look again I see "do_audio_output[1] so guessing my first edit is irrelevant...
Again many thanks.
