New user needs advice
Token
Good write up except that portion. The Softrock I have covers the WHOLE HF spectrum. Ths one here is a newer model.
I stand corrected. I have not looked closely at the Softrock models that could be purchased since I gave mine away, I had noted the Ensemble II was wider banded, but did not know it was full band. The web page I looked at (Ensemble RX II Builders' Notes) for the Softrock Esemble II only listed the freqs as Band 0=1.8-2.0, Band 1=3.5-7.3, Band 2=10.1-18.168, and Band 4=21.0-29.7.
However, looking at the schematic the rest of the design, including the front end, basic BPF (although mine was a single BPF instead of four selectable ones), QSD, and QCG are all identical to the Softrock that I had (I believe an SR Lite II), so other than bandwidth the performance should be identical.
The performance of my softrock easily surpasses my RX320D. The RX320 is a well regarded radio for the bang/buck as well as utility and DX ability (providing antenna which is the case for any rig).
For weak signal DX I would pick the Softrock any day of the week. For utility I would have to give a slight edge to the RX320.
Here is what you get.
For $300+/- you could get an RX320 that is documented to be equal to/pull ahead of a $600+/- receiver (R75). Or IMHO you could get a cheaper Softrock (like mine full coverage) that can hang with a $300+/- receiver which in turn can hang with a R75.
Unfortunately the Softrock surpassing the RX320D or the R-75 is not supported by any testing I am aware of.
The Softrock with no external added preamplifier is considered to have a noise floor of between -108 and -112 dBm, depending on what source is quoted (not withstanding the occasional -123 to -140 claim on the Softrock Yahoo group...yes, I am a member). Except for the V9.0 kit, claiming “at least” –120 dBm, but not independently confirmed that I can find. I also expect it depends on who built the kit.
The RX320D has been measured to have a noise floor of -124 dBm, some sources quote more like -126 dBm. The Icom R-75 has a noise floor of -123 dBm with preamp off, and -130 dBm with preamp on.
This means that both the R-75 and the RX320D will have an extra 3 or more dB on the Softrock, possibly as much as an extra 22 dB. In its simplest form this means the Softrock can not see as far down as the other two, as long as the natural noise environment allows it to be used.
The RX320D has a sensitivity of 0.3 microVolt (for 10 dB SN). The R-75 has 0.2 microVolt. The Softrock is variously quoted as about 0.6 microVolt. Again meaning the Softrock does not stack up to the other two.
And we have not discussed phase noise yet. While the Softrock is pretty good with the Si570 osc it is still not up to the levels found in the R-75.
However, the Softrock, and ALL SDRs, are going to kill the RX320D and the R-75 in the areas of narrow spaced dynamic range, filter ultimate blocking, and filter adaptability. That means that when you have two close spaced signals any SDR; as long as the code is written well, can outperform even the very best, mutli-thousand dollar professional conventional radio.
However, lets forget all of that, call all of the radios the same in noise floor and sensitivity, for the rest of this discussion. And accept that SDRs do some things better than conventional radios.
As far as the $300+/- RX pulling ahead of the $600+/- RX, that is debateable, however the $300 one will definately not do it without a $300+ computer attached. It is an apples and oranges thing. The two are roughly equal, but one will operate all by itself and is thus more complex, changing the cost and value.
Yes, I know any SDR will also need a computer, but I was addressing the cost comparison of the RX320 to the R-75. Add the required minimal equipment for operation and the cost delta is completely gone, if not turned in the other direction.
Choice is yours but in all my years of radio (about 25 or so) the Softrock and RX320 are very impressive radios. Sure there are a Winradio out there that has more "virtual" knobs, there are radios that have more physical knobs. But really, really, given the exact same situation (antenna and all) would you really hear more then me? Would you SSB REALLY sound better then mine? Can I really sit there and justify a $XXXX price increase in the performance of one of those rigs?
I don't really think they would have anything that would "wow" me outta $500-800 dollars. It's about bang to buck for me and I think I would be hard pressed to find anything that would hear more then what I have. Some might do the hearing more spiffy then others but that is not the point.
Yes, the Softrock is impressive, particularly for what it cost, it is outstanding for the cost. 25 years ago if you had described its abilities to me and told me the price tag I would have asked if you had had a drug test recently. The RX320D is also impressive, although it cost slightly more. The R-75 is in the same boat, but able to be used stand-alone.
If you are asking about listening to a single frequency, and the MDS and sensitivity numbers above are correct, then yes the other radios will indeed “sound” better than the Softrock when operating at marginal levels in a low noise environment. Naturally not when the signal is strong enough to achieve a decent SNR on the Softrock or if the natural noise floor is high enough so that the advantage of the other radios cannot be used. Of course, such a claim is always arguable, what does “better” mean? However, you are missing part of the ride here as far as SDRs are concerned, it is not about physical knobs or virtual knobs, or all about sounding “better” (of course, all of those things can be factors).
First and foremost, can the Softrock display 1 MHz of bandwidth to assist you in finding new and interesting signals? No. If you have the very best sound card possible it can display 190 kHz, when I used mine I got 48 kHz with the best results (could go more but 48 kHz seemed to work out best, and I never bothered to upgrade the sound card) and most users I know of are dealing with about 96 kHz max. And the WinRadio Excalibur will display up to 50 MHz at one time, more than 250 times the max possible instantaneous display window of the Softrock. As I have said before, you can see every single signal that pops up above your noise floor, across the entire HF spectrum, at one time, and you can look back in time 600 seconds (the amount of time kept on the waterfall display) to see what signals you missed while looking at something else. And this is a feature I use essentially every single time I set down at the radio.
Given the exact same situation, antenna and all, as you have asked, yes, I will hear more than you. The wider bandwidth display will allow me to catch short duration signals easier and more often, I do not have to be in the right place at the right time, I am everyplace at the right time. That is a fact. In fact, the problem becomes information overload, there is so much there that you have to skip some of it. Now, if I am just tuning to one frequency to listen to a scheduled broadcast this will not matter, but I almost never do that, and when I do I use one of the conventional radios, like the R-75 for example. The fact that the Excalibur can place three individual receivers in the DDC bandwidth means I can listen to or monitor, with one radio, three widely separated frequencies at one time. And the fact that the published numbers say the Excalibur is more sensitive and has a lower noise floor means that I can detect and use lower level signals.
I don’t know if you can justify the price increase for these rigs over something like the Softrock, only you can answer that. However I certainly can, and have.
Having used many radios and systems in the last 40+ years, including some of the best intercept and countermeasures gear Uncle Sugar could afford, I can easily see the value of radios like the R-75, the WinRadio Excalibur, the Microtelecom Perseus, and even the Softrocks. But I can also see the differences and the advantages of each.
Don't get me wrong here; I am not badmouthing the Softrock series at all. For the money they cannot be beat. Even for several times their cost they are excellent. But that does not mean that other radios are not better. Perhaps better is the wrong word, make that other radios can be more capable.
But, I will be ordering another Softrock kit as soon as I find a source with them in stock. The Ensemble II intrigues me, I can always use another low cost RX and really the only reason I did not keep my last SR was because of the limited tuning range. But, had I kept my SR I still would have gotten my other SDRs.
T!
Mohave Desert, California, USA
corbintechboy
Corbin, KY
Good write up.
This is what I have found (by ear only)
The Softrock is great for looking at a signal and "clicking" where to listen. In this respect it is much better then the RX320. The noise floor seemed almost null on my system (Sound Blaster Audugy Platinum). The softrock was the most silent radio I have ever heard in my life. That may also translate to less sensitive, I don't know but it worked great. The only big issue I had is the frequency calibration is was off on mine.
The RX320 is noisy! No other issue with the radio other then the noise. I have tamed it down to what I believe is the lowest I can get it (chokes and whatnot).
I don't really know that seeing so much spectrum would be of any use to me. I utility DX and broadcast DX and it may be great being able to record such a huge chunk and being able to go back and catch some info for a QSL.
I thank you for all that write up. Was very informative.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Keep something in mind here. The 320 is NOT a DSP receiver, despite some of the ads and hype - it has a standard audio amp and several other non-DSP components. Therefore a comparison of the 320 to any other DSP radio isn't really valid.
That being said, SDR radios really are the wave of the future. Sadly, the R75 (and the forthcoming AOR radio) may be the last of their breed. There will always be some that prefer a dial to twiddle.
But as an entry-level radio, the 320 really can't be beat at its price point.
Excellent discussion all 73 Mike
Midland, Michigan
Thank you for the lesson
Great discussion...all of you.
Is it possible to buy a SoftRock RX Ensemble II that is already built? Or is building a kit the only way to do this?
corbintechboy
Corbin, KY
I bought mine already built. If you join the Yahoo group you could find someone to build it for you (the maker of the kits built mine).
Cville
SC
The 7070? Do you think it's other than vaporware? I'd love to see it.
Midland, Michigan
Leaning towards Softrock Ensemble
Folks
Thank you again for providing your knowledge to a person to enter the world of SDR.
I'm starting to lean towards the Softrock Ensemble II as a beginner system.
I've done some reading on the internet regarding software to run SDRs in general. It appears that new software is released on a regular basis, depending on the receiver. The shear variety of new software is a little bit overwhelming to me. I wish I could just test drive this stuff ahead of time.
Can anyone comment on the pros and cons of different options for software to support the Softrock Ensemble II?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's still in the Prototype stage:
H-Mode Frontend
Indeed; and here's another page with some more pix...
AR7070 DSP HF Receiver - N9EWO
The problem is that the price point may be so high that it knocks all but the folks with lots of money out of the park...
By the way, when I mentioned 'radios with knobs', I neglected to mention the upcoming SR8 from Alinco, due out just shy of Xmas, according to the Universal website, so just to set the record straight...
Alinco DX-R8T Alinco DX-R8 Receiver
73 Mike
